查看: 8477|回复: 28
Altium Designer 14.2.3 31718 最新安装版
发表于 2014-2-23 14:47:20 | 显示全部楼层 |阅读模式
最新官方正版AD下载地址:
Release Notes for Altium designer Version 14.2
Version 14.2.3
Build: 31718   Date:19 February 2014
1151        Schematic drawing line object now supports "dash dotted" line style.
1152        Schematic Pin object now includes Line Width attribute for Symbols.
1279        Schematic arcs now always display correctly at different zoom levels.
1313        Schematic documents now render non english text correctly when saving between AD10 and AD14 formats.
1331        Box.Net publisher has been updated and now uploads files correctly.
1345        The "Create Primitives From Board Shape" command now correctly uses arcs instead of line segments.
1349        DBLib and SVNLib using MySQL will now attempt to reconnect automatically to the server after PC hibernation or lost connection. BC:2824  BC:1930
1357        Subversion commit comments now support quotation marks. BC:1661
1358        Subversion commit comments now properly support different language input text. BC:2133
1363        Subversion 1.8 support has been added. This also includes support for the new working folder format, as well as updating the built-in Subversion Client to version 1.8.4. BC:3193
1392        orcad Capture export now correctly handles Power, GND and test point objects.
1457        PCB Drill Table has been updated to include new Text Alignment and Column Width settings (available from the right-click menu).
1458        Schematic now supports vector graphic images (.wmf and .svg).
1459        PCB Polygon repour speed has been significantly improved. Speed increase up to 20x depending on number and complexity of polygons.
1478        There is no longer a hang when running the automatic loop removal tool.
1482        PCB footprint primitives are no longer removed from the footprint during interactive routing.
1484        Loop removal will no longer remove incorrect track.
1485        PCB Polygon Pour quality has been improved when using hatched style and polygon cutouts.
1486        PCB Design Rule dialog will now grey out disabled rules making it easier to distinguish between enabled and disabled rules.
1516        The PCB Library Report can now support non english characters.
1529        Schematic documents now render text correctly when using non english language system settings.
1531        Smart PDF now supports an option to include "Global Bookmarks for Components and Nets".
1547        PCB Copy Room Formats command will no longer copy the board region.
1550        pads Library importer has been updated to fix specific cases where components were not created.
1551        DxDesigner importer has been updated to fix connection issues with off grid objects.
1555        PCB Via stitching has been improved and will now properly use the clearance rule settings.
1579        Schematic Formatting Toolbar can now change text font and size settings.
1580        STEP model clearance errors between top and bottom layers has been fixed.
1581        Selecting PCB components in Single Layer Mode will now only select components which are on that layer. BC:3545  BC:997
1582        Schematic directives no longer produce false error reports when single documents are compiled.
1584        The PCB Printout Properties dialog now opens correctly even if the PCB is not the top document window.
1585        Use of the backslash character (\) in an Output Job container file name no longer inserts an underscore character (_).
1586        The PCB Drill Table is now correctly re-positioned when using the Move»Move Selection by X,Y command.
1587        Scripts using SchServer.RobotManager.SendMessage can now be run successfully,
1588        PCB Undo now works correctly when primitives are deleted from a component.
1594        The PCB "Update Free Primitives From Component Pads" command no longer removes vias from their nets.
1601        The Locked attribute is no longer updated when changing the Pad or Via test point settings. BC:3758
1604        Deselecting the Preview top - bottom layer command for a drill table, will no longer cause an Access Violation.
1608        PCB polygon thermal relief calculation causing incorrect DRC violations in some situations has been fixed.
1612        IDF Export has been updated to fix a hang when exporting from specific files.
1616        The Libraries Panel now remembers the layout when the application is restarted.
1617        There is no longer a discrepancy in the display of top and bottom SM layers when opacity is set to 50%.
1618        Smart PDF now displays the correct component parameters when using Variants. BC:2517  BC:3201
1619        BOM generation now supports variant supplier and supplier part number parameters. BC:3222
1620        Variants now support the .COMMENT and .REFDES special fields. BC:2083
1624        The Schematic "Update From Libraries" command has been updated. The "Preserve Parameter locations" option now works correctly and a new option "Preserve parameter visibility" has been added. BC:59  BC:839
1626        Automatic adjustments to track end-points when moving a selected track can now be reliably undone using the Undo feature. BC:431
今天好开心啊,前来签到..!
发表于 2014-3-3 10:06:59 | 显示全部楼层
正在下载,试试鲜
发表于 2014-3-16 11:40:03 | 显示全部楼层
bjgaofei6688 发表于 2014-3-3 10:06
正在下载,试试鲜
我自己也在用了,哈哈
今天好开心啊,前来签到..!
4万
发表于 2014-3-22 23:07:25 | 显示全部楼层
[udu_catsoul=5]给力![/udu_catsoul]
发表于 2017-5-23 07:34:21 | 显示全部楼层
资料很好,值得借鉴
发表于 2017-5-25 02:27:05 | 显示全部楼层
支持~~很不错的资料,下载中
发表于 2017-6-22 16:13:07 | 显示全部楼层
yxa
63
发表于 2017-6-22 18:12:11 | 显示全部楼层
回复一下,获取下载   嘿嘿
yxa
63
发表于 2017-6-25 08:54:16 | 显示全部楼层
正好需要,感谢分享 赞...
发表于 2017-6-29 08:19:32 | 显示全部楼层
山无棱天地合才敢与君绝 哈哈
