查看: 343|回复: 0
Wallys|QSDK Routerboard IPQ8074A/IPQ8072 4x4 2.4G 8x8 5G QCN9074/QCN9024/QCA9...
发表于 2022-10-19 11:59:17 | 显示全部楼层 |阅读模式
Wallys|QSDK Routerboard IPQ8074A/IPQ8072 4x4 2.4G 8x8 5G QCN9074/QCN9024/QCA9880/QCA9882 moudles
With a history of 10 years, Wallys has been very mature in the design and development of hardware and software in wireless communication. It also supports customization and software development, and has won the trust of 90% of customers around the world and reached a long-term cooperative relationship. It is also a supplier of facebook.
Wallys mainly uses Qualcomm and MTK chips. The main products include router, moudle, industrial access AP and antenna, which are of industrial grade, and the quality and performance fully meet the requirements of users.
The following are the best-selling products of Wallys. Let's take a look at them together. You can contact us at any time if you are in need, or enter our company's official website to check more product information.
Skype/EMAILsales@wallystech.com
WEB:https://www.wallystech.com/
DR8074A(HK01)
IPQ8074 is Qualcomm's first WiFi6 networking solution designed to meet the growing demands of increasingly crowded and dense Wi-Fi environments. It offers the best configuration to bring unprecedented capacity and coverage to Wi-Fi networks and supports several unique features to ensure the best Wi-Fi performance for all types of applications.
IPQ8074A has added the MU-MIMO Uplink, OFDMA-UL, MU-RTS (Multi-User Request To Send), Preamble Finally, Spatial Reuse (OBSS PD). Maximizing the payload data rate by improving efficiency reduces contention between STAs and improves channel utilization. This shows that IPQ8074A can have more stable and higher wireless data rate, anti-interference ability is also more excellent.
IPQ8074A 4x4 2.4G 8x8 5G 802.11ax
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU
■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
Wallys will design its own version to support MINI PCIE/M.2 moudle. Meanwhile, moudle supports 2.4G/5G/6G, which can meet customers' various parameter requirements. If customers need customization, Wallys can customize hardware and software.
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world's customers and is a supplier to facebook.
From 802.11n to 802.11ax, it has been moving forward, and has been trusted and supported by more and more customers.
wallys also supports custom development of software and hardware, including customized products.
DR9074-6E(PN02.7)****(QCN9074/QCN9024 Series of moudle)
QCN9074 supports 4x4MIMO, and the maximum speed can reach 4804Mbps in theory when the bandwidth is set to 160MHz. If you use 2x2MMO, you can support 4096-QAM with a theoretical maximum rate of 2882Mbps.
QCN9074 802.11ax 4x4 MU-MIMO 6GHz wifi6E
QCN9074 11ax 4x4 6G M.2
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
DR900VX(QCA9880/QCA9882 Series of moudle)
Qualcomm Atheros QCA9880 is a highly integrated WLAN SoC that can be used in 5GHz 802.11ac or 2.4/5GHz 802.11n WLAN products. QCA9880 supports 33 MIMO and can be used for high-speed wireless data transmission applications. QCA9880 integrates a MAC, PHY, ADC, DAC, 33 MIMO wireless transceiver that supports multiple protocols. QCA9880 uses PCI-e interface to communicate with the outside world.
Qualcomm Atheros QCA9882 is a highly integrated wireless LAN (WLAN) system-on-chip (SoC) for 5GHz 802.11ac or 2.4/5GHz 802.11n WLAN applications. The QCA 9882 integrates an on-board cpu for the wireless LAN physical layer (Phy) and lower level Settings of the rf to offload the host processor to other tasks
QCA9880 802.11ac Dual band
QCA9880 3x3 2.4G/5G FCC/CE/IC
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
FCC,CE and IC Certification
APPLICATIONS
  • Profi WiFi hotspot coverage
  • Commercial radio coverage
  • Hotel Wireless application
  • Country coverage
  • Internet for passengers (bus, train, plane, …)
  • Security Surveillance
  • Some special scene application
  • Heavy-duty industrial environment use
