| ) @0 h" ^+ j8 I4 M; d, V8 \( j
Block8 T! L" V4 ~, g- _! ^
Function 8 [) Q8 W; C2 n$ O4 `$ L" s
/ `2 Y/ n- X: v, k, M6 f; X- KEpson Products $ m* w$ O8 N+ O
/ Q# h" ^$ X# e7 F& U
Function , I3 N& @; I. b u. \. R& }
6 X( S4 \; f r6 w9 ~; h8 vCategory / g/ e R9 M0 s7 N
| , l: h: k6 _3 M+ J
Model
4 M; L+ I. P; ]& V# M | ! f/ H) @5 d: V# i
Description 1
$ o" s7 ~4 I4 Z* H) b* r |
' |$ [& V2 V% ~ ]/ J3 X' w. g/ c0 a. IDescription 2
- T; o4 J3 y" l |
* v9 N) ^( s Q |# N, YA
$ _% E6 W8 O0 M+ |2 i$ v | ; T( M4 F0 J# i6 g$ w& A- ]
MCU
. K0 ]% z/ k5 w7 x% h | , S9 }% K6 Z$ k, H g3 w
Clock
( D$ _% ^; `9 ~ B- G' F) L! A |
% F5 S N5 G! d9 p: a, oCrystal unit
8 N8 D8 _7 t S2 G3 J1 Z | ) ^) k/ r' c6 S4 p, j7 j
MA-4066 j3 |) T* K& Q7 O
FA-238 $ W3 p; o5 w+ _0 C% L
| - e0 j5 p/ n" n5 b: W0 E8 b
4MHz, 8MHz, 12MHz
3 Y7 l; x2 P6 v' E( P | |
2 _. Q# _ k5 q DB 9 U, _; f8 |. [1 v: p W
| : F+ |0 m& |4 j# s% f
MCU 8 O; R6 |& S& r* }2 w6 X; v- w
4 T& r" {$ x1 Z/ q/ Y$ y$ uRTC
@/ R4 T# u. c8 b1 T |
7 n! k. `/ I$ G7 {+ NBuilt in9 N8 ~7 z* R" `; o
Crystal unit
! I! D0 M+ A! z/ L! ^ | # o. v2 R! A' p( T2 z( r# F
RX6110SA # Z( S- j# a7 l; y6 y; K
| 6 J, @) o) X* |3 v: x
I2C & SPI
# H6 Y) c* ~, G: L& e4 ]: F |
! G6 W2 V; f% g5 e( nLow Power 6 ]) _% T! H$ {& c9 j8 e
$ v) q' H* b2 d* z& `' BB
3 h& L3 X' {) a' T |
9 q6 v. |8 Q3 g0 vMCU
& u: L8 \' C$ _' z | ( k; Q d. b7 d( Y/ L: @7 N) m
RTC
; e5 u3 X# h4 ]4 J |
{7 a: O4 o3 ?. r$ j/ S3 yBuilt in8 K& ?: S$ }) R1 x2 U
Crystal unit
7 H/ f" ~, p' }& g g3 u | 5 q' d, T( x4 `" [% e5 a
RX-8803SA5 ~( w5 H0 N: u3 d
RX-8803LC / ?5 g8 |, w# N* i. G
| ; j0 [2 H) M. `
I2C 7 C6 \3 J H% ?! ?
# ~5 f9 a6 D7 ?7 mHight stability @2 w$ p) i# _ T
% v7 n, O- p: A" c6 n" F' pB
( S$ j$ F# j5 L: v, o( X! s2 i! ~7 g |
1 I+ W9 Y$ W& K' x8 f: a& zMCU
* v/ b! v3 o) l( ?% q+ f | + P- f- ^0 l# d. m0 b0 z& o
RTC
, X y! j" Z/ F3 U; G, W: O9 x | ) b X/ o: z4 j, r" X
Built in" K1 d8 @2 E) @
Crystal unit c M6 T- }6 j. O4 @' A- {" ~
+ S: E5 B1 G( F+ o5 v2 n$ m* b sRX-4803SA, Z0 P8 j7 c# g: g2 t* t/ n
RX-4803LC 0 g2 u" s8 \4 b5 j; y' K) M
! q3 X9 e3 }& h0 qSPI
7 q6 M' J6 d* C |
+ ~$ E% L% k8 y9 vHight stability ' E0 g' n# l# W& d7 E# U
8 Q( Q) c. N. s$ _" H4 j1 ~" NC % P- b- |9 W& S* Y
8 W9 |9 C' D$ ZCommunication unit - X" W. }1 A# L" s
| 9 d" U! P/ m) K8 L
W-PAN
7 A+ F* ?; A' |+ `0 ` m" X |
9 T, D) l* ~2 D; C' fCrystal unit
5 B5 i2 P5 |% O | : f3 c& @" ?$ a7 K* s
TSX-3225# E. H) C2 r' y2 J; \) }/ w7 S
FA-20H) e0 j. A- x0 U* @, D
FA-128 # a: H" Y9 B9 S G Y4 }' H7 O- V
4 _6 T( [, |& o5 Z: R5 ~- Q26MHz, 30MHz, 32MHz
8 ]7 g5 G9 |4 X. w$ i | |
7 j/ I! H' I& S4 m+ S/ PC
6 s/ O w3 Q: x2 N |
" e Z# | a `8 u: }Communication unit
" x% S* ~. Y: n |
r& I' J/ b4 R; N9 D/ f) `, ~4 `: z. FW-PAN 0 d0 H- f3 j4 U0 l7 P
| 4 @- q: i0 G3 G0 J0 q
TCXO ( X0 I" C# n' P+ |( Z$ |
! u$ g9 B9 g) E' Z1 A; u( G1 c: yTG-5021CG- L8 \+ X$ g2 N7 h1 [: p
TG-5021CE" h+ ^) E P; e" k3 \6 W. F
TG-5006CJ
) S5 c3 [+ o! N0 p2 pTG-5006CG* y% |+ ^2 R( @7 R6 V6 |+ e
TG-5006CE
/ r9 [& _+ l1 m% Z* t$ I, k% ^ |
' H F% r) B$ }( Q' e: h" X26MHz, 30MHz, 32MHz 6 n" m1 t4 R" @" F
; G0 Y: W0 \$ B9 m: U) m dC
6 s: O" w! v0 R! a& ?. b) d |
# V+ \8 a6 `7 v9 \! Y% }: kCommunication unit + {8 |% U! A8 t) Q- _% |5 R
| . `* ]9 C/ e w! z' e
W-LAN . u+ G; d) M& T5 p. W% P$ Z& K q
| 4 G2 X# i9 _% ~" f2 Q: c2 R7 }
Crystal unit
/ a) X8 j. v. i( I |
0 R! z, i: Y0 b5 ?TSX-3225
" m# s' R3 d% x. t2 @FA-20H, E: [- N. t3 Q0 M
FA-128
# o6 E4 L7 U8 k+ Z, L: R% E, U |
: j7 O: ]* r# x8 }26MHz, 30MHz, 32MHz
+ m. @, [. Y, V/ P5 \ | |
# c E7 `/ `' r- ?
D
+ z e2 Z9 Y3 C4 R | 0 U V9 `( N8 ] y1 H
Ethernet
- g/ F: m5 \& o | 4 z9 n: x# g* _9 J/ v
Clock
1 h# \( J1 a x% [8 G, ? |
6 c8 }# H- b" ]2 P jSPXO
+ c( |( n# y% o4 w | 1 i9 n$ o' s; J+ T
SG-210STF 8 |& e1 S, `, N3 B
7 v+ P- j- w y1 T25MHz, 50MHz ; p4 H- ]1 l8 _4 o( S
* L- m2 x, T# h9 a
D ) I, r( f5 o' r* I, B
| - f/ t# @2 _, ~) c6 V
Ethernet
* Z2 D6 ?! X5 O9 \% A# I6 ` |
, a1 X# E* o+ _' e% {5 q4 l0 ?Clock " p$ _- A% A1 Z0 u% R& g1 c* V
4 s% U S5 f8 w( \, ]" u, N- C6 YCrystal unit
) c9 w/ S" T# Z; d |
5 f n A" w& d9 b7 o" RFA-238 + w# S5 j6 j }: f* j% O; Q5 j
| % C. V8 S$ [, I9 h
25MHz, 50MHz & `, i3 d1 ^9 ?
