查看: 315|回复: 1
QCN9274 QCN6274|A Comprehensive Guide for Wallys WiFi7 Offering
发表于 2023-12-29 17:03:28 | 显示全部楼层 |阅读模式
Explore Wallys' WiFi 7 Module Offering: A Comprehensive Guide
Wallys, a pioneer in connectivity solutions, introduces an array of advanced WiFi 7 modules designed to cater to diverse needs. Let's delve into the details of Wallys' WiFi 7 modules and compare their specifications through informative data sheets.
A Quick Overview
1. DR9274-QCN9274|QCN6274 WiFi7 Single Band 5G
https://www.wallystech.com/Network_Card/DR9274-5G-wifi7-card-moulde-Qualcomm-QCN9274-M.2-Slot-4x4-5G-single-band-Wallys.html
2. DR9274-QCN9274|QCN6274 WiFi7 Single Band 6G
https://www.wallystech.com/Network_Card/DR9274-6G-wifi7-card-moulde-Qualcomm-QCN9274-M.2-Slot-4x4-6G-single-band-Wallys.html
3. DR9274-QCN9274|QCN6274 WiFi7 Dual Band Dual Concurrent-2.4G&5G
https://www.wallystech.com/Network_Card/DR9274-DB-wifi7-card-moulde-Qualcomm-QCN9274-QCN6274-M.2-Slot-2x2-2.4G-2x2-5G-dual-band-Wallys.html
4. DR9274-QCN9274|QCN6274 WiFi7 Dual Band Dual Concurrent-5G&6G
https://www.wallystech.com/Network_Card/DR9274-5G6G-wifi7-card-moulde-Qualcomm-QCN9274-M.2-Slot-2x2-5G-2x2-6G-dual-band-Wallys.html
5. WiFi7 Platform DR9574
https://www.wallystech.com/Routerboard/DR9574-wifi7-Qualcomm-IPQ9574-QCN9247-4x4-2.4G-4xM.2-Slot-QCN6274-QCN9274-Ethernet-Port-2x10G-4x1G-Wallys.html
1.DR9274-5G|QCN9274/QCN6274 WiFi7 Single Band 5G
Tailored for single-band 5G applications
Powered by Qualcomm's QCN9274 'Waikiki' series
Features 4×4 MU-MIMO and supports up to 4096-QAM
Operating temperature ranges from -20°C to 70°C for commercial grade and -40°C to 85°C for industrial grade
Qualcomm Atheros QCN9274 for Industrial Grade;
Qualcomm Atheros QCN6274 for  Commercial Grade;
Maxim Tx power 20dBm per chain;
4x4 5G MU-MIMO, up to 5765Mbps physical data rate;
Support up to 4096-QAM;
M.2 connector;
PCI Express 3.0 Interface
2.DR9274-6G|QCN9274/QCN6274 WiFi7 Single Band 6G
Specifically designed for single-band 6G requirements
Utilizes Qualcomm's QCN6274 'Waikiki' series for robust performance
Boasts a 4T4R (4×4) MU-MIMO 6GHz solution
Achieves up to 11.530Gbps with 4 spatial streams
3.DR9274-DB|QCN9274/QCN6274 WiFi7 Dual Band Dual Concurrent-2.4G&5G
Perfect for dual-band, dual-concurrent operation in both 2.4G and 5G
Employs Qualcomm's QCN6274 'Waikiki' series for exceptional connectivity
Supports both Access Point (AP) and Station (STA) modes simultaneously
4.DR9274-5G6G|QCN9274/QCN6274 WiFi7 Dual Band Dual Concurrent-5G&6G
Tailored for dual-band, dual-concurrent operation in 5G and 6G frequencies
Utilizes Qualcomm's QCN9274 'Waikiki' series for reliable performance
Wide signal coverage with a 5V design
5.WiFi7 Platform DR9574-IPQ9574
A robust platform featuring the Qualcomm IPQ9574 or IPQ9554
Designed specifically for WiFi 7 router applications Industrial
Wallys' WiFi 7 modules are engineered for versatility and reliability, making them ideal for Enterprise, Industrial, Cybersecurity, Transportation, and SMB applications. The modules support Multi-Link Operation (MLO) for reduced latency, Preamble Puncturing for improved spectral efficiency, and unique features like FIPS L2 for enhanced cryptographic protection.
For detailed technical specifications and further information, visit our website: https://www.wallystech.com/Network_Card/DR9274-5G-wifi7-card-moulde-Qualcomm-QCN9274-M.2-Slot-4x4-5G-single-band-Wallys.html.
Inquiries:
For inquiries or to discuss your specific requirements, please contact our dedicated sales team at sales1@wallystech.com.
Wallys - Empowering Connectivity, Driving Innovation.
发表于 2024-1-4 16:57:40 | 显示全部楼层
射频前端芯片设计原厂三伍微电子的产品有WIFI FEM、IOT FEM、PA和开关。
产品优势
FEM优势:(1)谐波好,免去外置滤波器,(2)无需调试匹配电路,直接替换。
开关优势:低插损,低延时,高频率(支持7.2GHz)
