查看: 5973|回复: 5
Allegro补丁Hotfix_SPB16.60.019_wint_1of1
最佳新人
发表于 2013-12-17 14:41:26 | 显示全部楼层 |阅读模式
书籍:
《Cadence Allegro16.6实战必备教程》
PCB3.COM网站创办人
发表于 2013-12-17 20:08:01 | 显示全部楼层
这个补丁改进了什么?
今天好开心啊,前来签到..!
最佳新人
发表于 2013-12-20 17:38:55 | 显示全部楼层
该补丁更稳定
书籍:
PCB3.COM网站创办人
最佳新人
发表于 2013-12-20 17:39:55 | 显示全部楼层
以下是更新内容
( a+ _. Q. W2 S1 ^, i: Q( I0 b/ wDATE: 11-15-2013   HOTFIX VERSION: 0191 F' V# \& E' L/ f
===================================================================================================================================& h# `$ H; l* s4 {/ }
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE# \7 o+ \+ b3 N, s9 y# t" ^( a
+ L& k! S& L/ W/ H' H( X( J" O- b+ I1176155 CONCEPT_HDL    CORE             Graphics remnants with 16.6 QIR 3
$ T1 Z9 ^, p7 v1 O1 K5 [; d1178272 CONCEPT_HDL    OTHER            Verilog netlist does not include split blocks correctly; i5 x2 F' j7 t
1190782 FSP            FPGA_SUPPORT     Support for Altera > 5SGXEA9N2F45 device.* v* s% j8 N) W& h# Q5 Z6 W" E6 O+ K( F
1194140 ADW            LRM              SYNC_PROPERTIES is not resolving issues a based sync_properties settings1 _8 e$ M4 M6 l
1195744 APD            EDIT_ETCH        Diff_Pair routing fails on certain Uvias in the pair.7 f* F' N; i6 U1 s
1196704 ALLEGRO_EDITOR INTERFACES       ENH: During ipc2581 export checkboxes corresponding to 縈iscellaneous Image Layers� should automatically get selected
/ y  n% J$ j/ S$ M! @) o3 A, R1 ~% k; Y1198340 ALLEGRO_EDITOR OTHER            Multiple -product option on the Allegro command line does not access the second -product0 a( h' Z3 T* f& f( A9 K% ]
1198596 ALLEGRO_EDITOR INTERFACES       When copper thickness is increased for the outer layers, step Viewer does not show correct component position.
* v' f8 w, v7 Z+ O& \2 }1199673 PCB_LIBRARIAN  OTHER            Component Browser fails to load footrpints if they are set with UNC path: X) t9 p4 a7 \* H( F$ ]% K
1199889 ALLEGRO_EDITOR DATABASE         Allegro crashing with latest hotfix.+ Z2 p' F" j* ~
1200303 ALLEGRO_EDITOR GRAPHICS         3D Viewer does not update after changing STEP model mapping6 t$ K! ?$ x0 h# F
1200449 ALLEGRO_EDITOR REPORTS          Allegro crashes when generating Net Loop Report.& v  H0 q1 V- s0 `9 E: g
1200915 ALLEGRO_EDITOR DATABASE         Reducing accuracy of this specific design crashes Allegro3 A; O& Y; u5 n- s- F/ _6 x
1201011 ADW            COMPONENT_BROWSE Component Browser crashes in DB mode7 E* r9 G% N' X! t; o- S" a
1201376 ALLEGRO_EDITOR INTERFACES       Allegro hangs when trying to map a specific STEP model to a package drawing.) v* r$ I  K+ m# I3 N0 n' z+ }
1201897 SIP_LAYOUT     IMPORT_DATA      BGA Pin Colors not matching the Colors defined in the Symbol Spreadsheet after updating.
4 N( i8 S: u0 a8 p+ k2 `/ Y: u1202709 ALLEGRO_EDITOR INTERFACES       STEP File generated from Allegro is not overwritten when the variable "set ads_textrevs
% ~9 E  `) F7 P: ^5 e% q1202820 ALLEGRO_EDITOR INTERFACES       Different xml generation for same step model on S106 and S017
5 F0 _, D0 l8 m# S1202842 ALLEGRO_EDITOR INTERFACES       Step model invisible for one pin dra in allegro 16.6 symbol editor
/ E3 X: {4 v8 f0 r1202983 ALLEGRO_EDITOR SHAPE            Shape voiding creates DRC with Route Keepout1 g4 P, V1 a( t  [3 L1 H
1203125 ALLEGRO_EDITOR OTHER            Exporting STEP file with External copper enabled does not show all copper when viewed with Solid Edge or Inventor
! [8 `7 H7 }6 f1 ]% {5 r- ?( b1203236 ALLEGRO_EDITOR INTERFACES       IPC2581 output with crosshatched shape is not correct0 o. p; Z$ X' z: i7 G' p- a+ j
1203995 CONCEPT_HDL    CHECKPLUS        CheckPlus rule, local_signal_no_offpage_body, getting an incorrect failure.  W" i, O! S! {) d0 ^
1204629 ALLEGRO_EDITOR SKILL            axlUIDataBrowse crashes the editor or returns error
' Q7 g/ v* ]: T2 ?* w, N1204640 SIP_LAYOUT     DIE_EDITOR       Concurrent co-design update fails& O, B1 n+ T4 {
1204881 SIP_LAYOUT     BGA_GENERATOR    Pin numbers are messed up after deleting a pin at a staggered bga# }* x- F% e; T" f% ^5 j
1204885 CONCEPT_HDL    CONSTRAINT_MGR   Cant assign discrete models after the wrong model was removed.. t5 ]5 c, v# a3 a3 p
1205374 ALLEGRO_EDITOR OTHER            pdf out command creates incorrect drill Symbol Characters placement in pdf file when setting film mirrored.
4 e" U$ a  B& x1205729 SIP_LAYOUT     DIE_EDITOR       update of codesign db fails on exit from die editor
# J6 R4 n" ^3 t9 |/ D% Y. H/ [1205801 ALLEGRO_EDITOR OTHER            Tool crash when do export IPF.
; @  V5 p8 {! K( t& j+ ~$ N! c1205881 CONSTRAINT_MGR OTHER            In CMGR , Objects > Create crashes Allegro
书籍:
PCB3.COM网站创办人
最佳新人
发表于 2013-12-21 00:15:36 | 显示全部楼层
不会装补丁
发表于 2022-4-14 08:49:20 | 显示全部楼层
66666666666666666666666666666666666666
* X; L8 J. D$ g; I0 z; y5 U
