DATE: 12-20-2013 HOTFIX VERSION: 021
1 i/ @5 I+ v5 K% U1 N===================================================================================================================================5 d) M8 v7 H, C
CCRID PRODUCT PRODUCTLEVEL2 TITLE
3 Z( K- N( P$ i" `; i# n===================================================================================================================================$ P7 Y3 @% M* |5 z, }. z" ]3 y4 {) Q
1214932 allegro_EDITOR OTHER Allegro will crash when performing show dimension on linear dimensions.
# K# i: i7 \! ~, ]. Q! N& S1215045 ALLEGRO_EDITOR SKILL Successive file open / ipc calls crashes Allegro 16.6
3 [$ O/ w8 K R1215115 ALLEGRO_EDITOR NC drawing name doesn't display in the ncdrill.log file) C/ [+ T5 V1 X9 r2 I% i
1216028 SIP_layout PLACEMENT Design will not update embedded component symbols.0 Y( V/ M6 |3 K
1218451 ALLEGRO_EDITOR DRC_CONSTR Route Keepout to Pin DRC created even after adding Void in RKO shape8 @3 J) D2 \- c( X% f0 r
1218636 ALLEGRO_EDITOR SCHEM_FTB netin process will rotate embedded symbols
$ O. d7 O% J1 y: U( E/ ]1218706 CONSTRAINT_MGR CONCEPT_HDL NCC associations get deleted from FE CM
; M4 u j, B# v9 \; Q+ S7 T+ ^) Q/ ^; V4 J0 \& ] o- U
& r$ s+ M* i7 Rhttp://pan.baidu.com/s/1o6K1BSY |
