查看: 1415|回复: 0
[作业已审核] PADS六月班刘政君第二周星期四作业
发表于 2019-7-17 09:30:19 | 显示全部楼层 |阅读模式
PAD STACK LIST REPORT -- Untitled -- Wed Jul 17 09:28:05 2019
Finger Pad Format -- Shape Size Orientation Length Offset
Annular Pad Format - Shape Size InnerDiameter
Pad Format --------- Shape Size
Thermal Format ----- Shape InnerDiameter OuterDiameter NSpokes Angle Width
Antipad Format ---- Shape OuterDiameter
Shape = O(OvalFinger),R(RectFinger),C(Circular),S(Square),A(Annular),D(Odd)
Pad Stack for Via: STANDARDVIA
Drill size 37
<Start> (1)                        C   55
<Inner Layers>                     C   55  (inner layers not otherwise described)
<End> (2)                          C   55
Pad Stack for Via: 8/16
Drill size 8
<Start> (1)                        C   16
<Inner Layers>                     C   16  (inner layers not otherwise described)
<End> (2)                          C   16
Pad Stack for Via: 12/24
Drill size 12
<Start> (1)                        C   24
                                   C   55  67  4  45   15  (thermal information)
<Inner Layers>                     C   24  (inner layers not otherwise described)
<End> (2)                          C   24
Pad Stack for Via: 10/22
Drill size 10
<Start> (1)                        C   22
<Inner Layers>                     C   22  (inner layers not otherwise described)
<End> (2)                          C   22
