查看: 4380|回复: 1
[已解答问题] 这种error该怎么解决?谢谢啊
发表于 2020-3-21 16:37:30 | 显示全部楼层 |阅读模式
LISTING: 1 element(s)
           < DRC ERROR >
  Class:           DRC ERROR CLASS
  Subclass:        ALL
  Origin xy:       (3481.8 430.3)
  Constraint:      Differential Pair Phase Tolerance
  Constraint Set:  DIFFP_PHASE_TOL
  Constraint Type: NET ELECTRICAL CONSTRAINTS
  Constraint value: 5 mil
  Actual value:     39.8 MIL
  Element type:    PIN_PAIR
  Pin Pair:        C171.2:J7.9
  PIN:          C171.2
  pinuse:       UNSPEC
  location-xy:  (3481.8 430.3)
  part of net name:  EDP_TX2N
  Constraint information:
    (SPhase) (Xnet=EDP_TX2N) J7.9 to C171.2  min= 141.1 MIL  max= 151.1 MIL  actual= 2922.4 MIL
    DPData: gap=8.1 (--0.1,+0.0) tolerance= 5.0; max uncoupled= -0.1
            (5840.3,329.4) pin J7.9,UNSPEC,TOP/TOP
      94.6 MIL cline TOP
            (5750.5,337.3) via TOP/BOTTOM
      2738.7 MIL cline ART04
            (3415.6,388.0) via TOP/BOTTOM
      89.1 MIL cline TOP
            (3481.8,430.3) pin C171.2,UNSPEC,TOP/TOP
  PIN:          J7.9
  pinuse:       UNSPEC
  location-xy:  (5840.3 329.4)
      94.6 MIL cline TOP
      89.1 MIL cline TOP
我知道答案 回答被采纳将会获得5 联盟币 + 1 联盟币 已有1人回答
发表于 2020-5-14 17:19:20 | 显示全部楼层
差分设置了对内等长。但是对内等长没有完成,所以报错。
