查看: 3189|回复: 0
LED大功率升降压恒流驱动芯片外围超简单可PWM模拟调光高效率驱动方案
发表于 2020-5-7 14:20:28 | 显示全部楼层 |阅读模式
) J4 A% f) I7 Q: ?1 B2 [  F! d AP5503 宽电压 LED 升降压型恒流芯片
0 {  L8 ]2 ?1 O3 c; J& R
  h9 g! J, u3 r3 P$ h6 j2 u5 m描述
& S9 X2 Y8 R# I3 qAP5503是电流模式DC / DC转换器,具有5 M" c( a) \; u+ b% a" S# p7 W6 y
用于驱动LED的外部电源NMOS。的! e" |! c0 q# c5 [: y/ H
AP5503在降压,升压和升压模式下用作LED驱动器
  j, u/ ~+ Y  o降压-升压模式。 LED电流可通过120mV感测电阻器在外部编程。用% |6 n0 x3 Y6 G: X
500KHz工作频率,外部电感和
. N- i1 B7 I; y7 y2 @* M, Z输入/输出电容器都可以很小。调光罐
* H5 N7 d* F9 K+ y: T. n可以是模拟,PWM或PWM转换为模拟
& p. L& g( [- r, L) l与外部电容器。
5 ~5 m" _/ D+ @& {AP5503采用MSOP-10(FD)封装
! T% h8 h& r2 q- j6 U特征) }7 d% R' U- e$ [9 `
„高电压:VIN最高60V,VOUT最高60V2 T( B/ f6 B& U7 {( F, N
降压,升压或降压-升压操作( T% v# R( s6 {4 \
„具有500KHz和200KHz的电流模式PWM  Q* N2 j( |; S# S
开关频率, [5 E1 X. P" `6 ~  z; m# n& `
„易于调光:使用一个外部电容器将模拟,PWM或PWM转换为模拟% P% T! ^1 K% F5 U
软启动以避免涌入电流
- t" ]* H3 c# @0 L  ~! n/ X可编程过压保护至极限
/ _4 Q# V7 c: C1 s/ a% h输出电压' t4 F4 v+ B$ f" A7 Y( o) t" T. s
VIN欠压锁定和热关断! o# i  O5 [0 J2 r" f
MSOP-10(FD)封装
; i" X% ]7 ^' S; I  e2 ~) k. A应用领域
4 V% Z" C* X4 P& J( eGPS,便携式DVD背光9 O) p+ B1 H* }$ h/ m, _+ @
„台灯和房间照明
' A$ `* R3 z0 t  M8 m工业显示屏背光
* G" z1 V8 P6 X/ \# v Description
9 Y9 b# G- S9 o; a! ?The AP5503 is a current mode DC/DC converter with
: f  E1 K* F  Z( F: loutside power NMOS designed to drive LEDs. The 2 C! j2 L" j% A
AP5503 operates as a LED driver in buck, boost and
; z* V4 \8 W: A' t% tbuck-boost mode. The LED current is externally programmable with a 120mV sense resistor. With a 2 ]& `" I* _3 q3 I
500KHz operating frequency, the external inductor and
9 b, |* j/ I9 ^6 S% D1 {input/output capacitors can all be small. Dimming can $ A- C; I/ L8 {$ K9 J. ]$ g
be either analog, PWM, or PWM converting to analog
; V# j& N; |9 M1 u7 R3 q  Bwith an external capacitor.
' E) {  G1 ~" U" _6 x$ H3 pThe AP5503 is available in MSOP-10 (FD) package.- r. c# `$ Q( ~  ~) o+ i
Features . o3 ^3 t6 A: B) G* V5 Y6 |
„ High Voltage : VIN up to 60V, VOUT up to 60V
# L9 q$ f5 M6 ^2 s" o„ Buck, Boost or Buck-Boost Operation
, e5 ^: I, [1 @) }„ Current Mode PWM with 500KHz and 200KHz & h5 y9 |: B" n
Switching Frequency
5 O8 _# [7 Y3 Z„ Easy dimming : Analog, PWM or PWM Converting to Analog with One External Capacitor + a9 B0 Y1 D3 y) {  y
„ Soft Start to Avoid Inrush Current & q$ X* N% O5 M( z" |7 V: A
„ Programmable Over Voltage Protection to Limit % h5 _  J, E7 y6 l3 ?, x6 H
Output Voltage
# E3 ?- p! ]: L- ]„ VIN Under Voltage Lockout and Thermal Shutdown
6 Q3 y; L) e( a1 {: E* V# c„ MSOP-10 (FD) Package
/ N5 b: n* {; g" I9 l% h  LApplications + B) P; ?4 ^% K8 |  a
„ GPS, Portable DVD Backlight & f- ~- n1 H7 l
„ Desk Light and Room Lighting
# Q9 @( M& c/ p! D„ Industrial Display Backlight$ l1 `6 D( I$ T; B* Y, s: G) h: h
8、样板申请联系: 1 G& Z% t- D8 U7 h" o5 ^
深圳市世微半导体有限公司 7 w' t5 \) ?; e
如需要了解可以联系欧阳: 18811874036 13714437124(微信)QQ:2355558464 2 ]4 S  q+ G( n6 C, M; g& l
深圳市宝安西乡街道宝源路名优采购中心B座1区3267 j7 d/ t. i/ L$ w* p8 C
0 Q* F8 }1 [: U7 ^5 [
