& P7 e$ D2 G" l5 i& s AP5503 宽电压 LED 升降压型恒流芯片
$ s: z5 Q1 q9 ]% g% V9 A* }. ?
2 K" E8 a! v% C9 W! a9 q' q8 Q描述! F9 H9 D; l* u o4 i
AP5503是电流模式DC / DC转换器,具有0 ~# X! E. b( Y: A
用于驱动LED的外部电源NMOS。的
( ], t% Y1 u6 p. HAP5503在降压,升压和升压模式下用作LED驱动器
. ?9 }! b0 O7 F' ]* k7 @降压-升压模式。 LED电流可通过120mV感测电阻器在外部编程。用' f8 V2 W* s9 ^8 t+ C
500KHz工作频率,外部电感和$ Y3 M/ K: {) }1 Z: K2 R
输入/输出电容器都可以很小。调光罐6 ~% b1 @5 s7 D4 B6 g
可以是模拟,PWM或PWM转换为模拟6 s5 X. J+ O, d
与外部电容器。4 f$ I1 @6 ~) N( Y/ v
AP5503采用MSOP-10(FD)封装。6 b B. R# q" L; ?
特征
- R0 n; F, b: ^5 z8 f4 T„高电压:VIN最高60V,VOUT最高60V
$ C5 p+ a0 `. R8 `! h, B降压,升压或降压-升压操作& y3 C0 t( u( g3 L$ y& A% Q
„具有500KHz和200KHz的电流模式PWM
4 V9 f+ s# R" Y1 ?开关频率0 z5 u6 r. w' G( w" F! R& \- _
„易于调光:使用一个外部电容器将模拟,PWM或PWM转换为模拟
+ p4 x7 r5 k! b4 E. h* T1 D软启动以避免涌入电流
7 E: |" j, O- ~" |可编程过压保护至极限3 e3 W2 }8 x/ l
输出电压
* L6 |' B" K/ {& D# yVIN欠压锁定和热关断
9 {) C' @: P' ^2 X/ f% fMSOP-10(FD)封装4 @2 s& x5 l7 L+ k1 N
应用领域, r8 ?/ Z7 |- C# G
GPS,便携式DVD背光
7 ?, Z: j8 X6 j! c„台灯和房间照明7 B6 U$ h4 A; z2 Y1 c# E
工业显示屏背光 U0 I* J) a; {' ^
Description
U2 V: n! c' ~6 R3 }The AP5503 is a current mode DC/DC converter with
, l$ C/ H/ K* S+ ]outside power NMOS designed to drive LEDs. The 2 d q* ~' `! o- n4 p
AP5503 operates as a LED driver in buck, boost and
C; O: h+ ^) L" j( ]buck-boost mode. The LED current is externally programmable with a 120mV sense resistor. With a - d0 b7 O* u9 G! F* A
500KHz operating frequency, the external inductor and
& ?$ i5 ?+ o2 |% C4 [7 z4 ^input/output capacitors can all be small. Dimming can 8 O. p# S; Z9 v$ |; D
be either analog, PWM, or PWM converting to analog 6 H H% O4 Y# _1 G2 F' r
with an external capacitor.
: K) D! F" c: \( D% m- n: D! [2 ~+ qThe AP5503 is available in MSOP-10 (FD) package.
$ h" D7 p4 Z: m8 o' D" \Features
4 t8 }# M' T/ u„ High Voltage : VIN up to 60V, VOUT up to 60V
& ^3 o0 z% e% x/ l9 h* g„ Buck, Boost or Buck-Boost Operation 7 e. G! m% A) {, t0 Z9 Y9 g
„ Current Mode PWM with 500KHz and 200KHz
- X; [' e1 I/ [0 u; W4 d2 JSwitching Frequency
; ]; l7 t) P. ]# t) U„ Easy dimming : Analog, PWM or PWM Converting to Analog with One External Capacitor
5 J) j: ]+ b h8 @5 D$ O„ Soft Start to Avoid Inrush Current # ]' ]& y) l9 {! }3 `
„ Programmable Over Voltage Protection to Limit
: c1 v8 n! @6 wOutput Voltage
7 v- t( B0 Q- I„ VIN Under Voltage Lockout and Thermal Shutdown
4 m9 T# A$ f) `. z" _, v2 q4 w„ MSOP-10 (FD) Package
+ ~ B6 F: Q, T# v) z0 u- j4 HApplications
( y, g: @/ V6 | U/ o# Z! g„ GPS, Portable DVD Backlight ! M/ O1 u0 }% D1 W; w2 ]5 K
„ Desk Light and Room Lighting $ h \8 I s' H( i7 k
„ Industrial Display Backlight
% U( d7 h8 _8 I7 s7 H6 \! O8 X8、样板申请联系:
( J* [9 I/ x* A% S深圳市世微半导体有限公司 ( { ] s8 g9 }* N
如需要了解可以联系欧阳: 18811874036 13714437124(微信)QQ:2355558464
9 m: o: ` w8 i! u深圳市宝安西乡街道宝源路名优采购中心B座1区326 0 o* u8 B1 |6 E; e7 S
! p- b0 j7 s' o: E9 r: o( K; a$ Q- h |
