查看: 5755|回复: 7
Cadence Hotfix_SPB16.60.014_wint_1of1(14号补丁)
发表于 2013-8-14 11:08:27 | 显示全部楼层 |阅读模式
2 H6 @0 x5 j6 Y! h% ~
DATE: 08-9-2013    HOTFIX VERSION: 014===================================================================================================================================CCRID   PRODUCT        PRODUCTLEVEL2   TITLE===================================================================================================================================1155569 APD            MODULES          P1_U1 and P1_U3 Die pins are missing after Place Module.1158528 CONCEPT_HDL    OTHER            Dual Monitor issue: Retain Hard Packaging option is missing and attribute test distorted1160968 allegro_EDITOR SKILL            Text Subclass change difference in Edit > Change and axlChangeLayer Skill command1161986 SIG_INTEGRITY  SIMULATION       Flatline waveform seen when via model is set to detailed closed form or analytical solution1162323 SIP_layout     DIE_EDITOR       Die Editor is incorrectly leaving an unassigned function pin in the die during refresh from die abstract1162752 ALLEGRO_EDITOR SKILL            axlDBChangeText doesnt recognize ?layer as a valid argument as documented1165002 GRE            CORE             GRE Crashes during Plan Spatial giving "Memory Allocation Failure" Error.1165469 CONCEPT_HDL    CORE             Import Design loses design library name1165708 ALLEGRO_EDITOR TESTPREP         Test point router failing when attempting to insert new TP via's1165801 CONCEPT_HDL    PDF              Pin texts of spun symbol overlap in publish PDF.1166020 SIP_LAYOUT     WIREBOND         Bondpads created with shapes do not follow the orthogonal pattern when adding wirebonds.1166371 ALLEGRO_EDITOR DATABASE         File locked for writing in 16.5 cannot be unlocked in 16.61166482 ALLEGRO_EDITOR INTERFACES       Step orientation for y-rotated component is not exported correctly.1167519 ALLEGRO_EDITOR DATABASE         Uprev dbdoctor does not log warnings about renaming properties.1167588 SIP_LAYOUT     DIE_ABSTRACT_IF  do not create a new pad stack for each I/O pad1168496 ALLEGRO_EDITOR SCHEM_FTB        Export Physical Crashes when netreving the board1169510 SIP_LAYOUT     WIZARDS          Netlist in Wizard is crashing with this text file where the Net Name for one of the assignments is blank, meaning dummy1169593 CONCEPT_HDL    PDF              Published PDF file's hyperlinks do not work fine when user click 1D10 or 2A10.1169984 F2B            PACKAGERXL       Error Mapping cset when packaging but not in CM Audit1171008 SIP_LAYOUT     OTHER            SiP Layout - Beta feature Void Adjacent Layer Shapes - changes or modifies "priority" of other/all shapes1171411 ALLEGRO_EDITOR OTHER            Enh - Break in Step 3D view in latest hotfix v16.6s013
  y5 M+ a# M7 Y: c1 j! Shttp://pan.baidu.com/share/link?shareid=4105765759&uk=3826038294
7 S  [7 o' p2 Q1 ?- q
发表于 2013-8-14 11:17:47 | 显示全部楼层
回帖奖励 +5 联盟币
发表于 2013-8-14 14:24:24 | 显示全部楼层
真的是太好了,十分感谢
发表于 2013-8-16 22:03:25 | 显示全部楼层
不错哦 喜欢 嘿嘿
最佳新人热心会员
发表于 2013-8-22 17:19:09 | 显示全部楼层
沙发!沙发!
发表于 2013-8-22 18:21:52 | 显示全部楼层
一直在寻找的资料,非常有用
发表于 2013-8-22 21:07:28 | 显示全部楼层
好像还不错!
发表于 2022-4-8 09:08:30 | 显示全部楼层
6666666666666666666666666666666666666
. E4 ]( s, U0 t( R3 o
