查看: 1615|回复: 0
Hi3861 炫彩灯板(DCL)开发
发表于 2020-11-13 09:57:22 | 显示全部楼层 |阅读模式
Hi3861 炫彩灯板(DCL)开发, 一、前言
HarmonyOS HiSpark Wi-Fi IoT 套件开发之
炫彩灯板 二、场景描述 场景设定:楼道 三、功能描述 感应照明灯,在光线比较暗的地方,感应到人体就会打开照明灯 四、功能实现 首先,通过人体红外感应检测人体运动 然后,通过光敏电阻检测光线亮度 最后,若满足有人且天黑的条件则亮灯 五、代码实现
  • * Copyright (c) 2020 Huawei Device Co., Ltd.
  • * Licensed under the Apache License, Version 2.0 (the “License“);
  • * you may not use this file except in compliance with the License.
  • * You may obtain a copy of the License at
  • *     http://www.apache.org/licenses/LICENSE-2.0
  • * Unless required by applicable law or agreed to in writing, software
  • * distributed under the License is distributed on an “AS IS“ BASIS,
  • * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  • * See the License for the specific language governing permissions and
  • * limitations under the License.
  •   * HiSpark_WiFi_IoT_DCL_VER.A板
  •   * GPIO_07 人体红外感应
  •   * GPIO_09 光敏电阻
  •   * GPIO_10 红色LED,高电平点亮
  •   * GPIO_11 绿色LED,高电平点亮
  •   * GPIO_12 蓝色LED,高电平点亮
  • #include <stdio.h>
  • #include <unistd.h>
  • #include “wifiiot_adc.h“
  • #include “ohos_init.h“
  • #include “cmsis_os2.h“
  • #include “wifiiot_gpio.h“
  • #include “wifiiot_gpio_ex.h“
  • #define LED_INTERVAL_TIME_US 300000
  • #define LED_TASK_STACK_SIZE 512
  • #define LED_TASK_PRIO 25
  • enum LedState {
  •     LED_ON = 0,
  •     LED_OFF,
  •     LED_SPARK,
  • enum LedState g_ledState = LED_OFF;
  • static void *LedTask(const char *arg)
  •     (void)arg;
  •     while (1) {
  •         WifiIotGpioValue rel=0;
  •         GpioGetInputVal(WIFI_IOT_IO_NAME_GPIO_7, &rel);
  •         unsigned short data = 0;
  •         AdcRead(WIFI_IOT_ADC_CHANNEL_4, &data, WIFI_IOT_ADC_EQU_MODEL_4, WIFI_IOT_ADC_CUR_BAIS_DEFAULT, 0);
  •         if(rel != 0 && data > 1500){//当感应到人体活动且天色较暗时,三色LED会闪烁
  •             g_ledState = LED_SPARK;
  •             // printf(“GPIO_7=%d, GPIO_9=%d\n“,(int)rel,data);
  •         else{
  •             g_ledState = LED_OFF;
  •         switch (g_ledState) {
  •             case LED_ON:
  •                 GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 1);
  •                 usleep(LED_INTERVAL_TIME_US);
  •                 break;
  •             case LED_OFF:
  •                 GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 0);
  •                 GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
  •                 GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 0);
  •                 break;
  •             case LED_SPARK:
  •                 GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
  •                 GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 1);
  •                 break;
  •             default:
  •                 break;
  •     return NULL;
  • static void LedExampleEntry(void)
  •     osThreadAttr_t attr;
  •     GpioInit();
  •     //设置IO为输入状态
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_7, WIFI_IOT_IO_FUNC_GPIO_7_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_7, WIFI_IOT_GPIO_DIR_IN);
  •     IoSetPull(WIFI_IOT_IO_NAME_GPIO_7, WIFI_IOT_IO_PULL_UP);
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_IO_FUNC_GPIO_9_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_GPIO_DIR_IN);
  •     //设置红色,绿色,蓝色 LED IO为输出状态
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
  •     attr.name = “LedTask“;
  •     attr.attr_bits = 0U;
  •     attr.cb_mem = NULL;
  •     attr.cb_size = 0U;
  •     attr.stack_mem = NULL;
  •     attr.stack_size = LED_TASK_STACK_SIZE;
  •     attr.priority = LED_TASK_PRIO;
  •     if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL) {
  •         printf(“[LedExample] Falied to create LedTask!\n“);
  • SYS_RUN(LedExampleEntry);
复制代码 六、编译
Screenshot from 2020-10-24 22-39-38.png (119.84 KB, 下载次数: 0)
下载附件  保存到相册
昨天 22:25 上传 七、烧录
Screenshot from 2020-10-24 22-41-03.png (50.65 KB, 下载次数: 0)
下载附件  保存到相册
昨天 22:25 上传 八、运行
下载附件  保存到相册
昨天 22:26 上传 九、总结 在编程过程中需要参考API文档,了解每个函数的定义,还需要参考硬件电路图,了解每个管脚的定义。感谢社区的大佬们提供帮助
