查看: 885|回复: 0
Hi3861 OLED显示板(OLED)开发
发表于 2020-11-13 09:57:46 | 显示全部楼层 |阅读模式
Hi3861 OLED显示板(OLED)开发, 一、前言
HarmonyOS HiSpark Wi-Fi IoT 套件开发之
OLED板 二、场景描述 场景设定:开机logo 三、功能描述 显示位图 四、功能实现 首先,编写oled驱动 然后,编写用例 最后,实现位图显示 五、代码实现 oled_example.c
  • #include <stdio.h>
  • #include <unistd.h>
  • #include “ohos_init.h“
  • #include “cmsis_os2.h“
  • #include “wifiiot_gpio.h“
  • #include “wifiiot_gpio_ex.h“
  • #include “wifiiot_i2c.h“
  • #include “ssd1306.h“
  • #define OLED_I2C_BAUDRATE 400*1000
  • static const unsigned char bitmap[] = {
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x00, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x0F, 0xF0, 0x00, 0x7F, 0xFF, 0xFF, 0xE0, 0x03, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x7F, 0xF8, 0x00, 0x3F, 0xFF, 0xFF, 0x80, 0x01, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFC, 0x00, 0x0F, 0xF8, 0x00, 0x0F, 0x80, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x7F, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x7F, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x3F, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x3F, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x1F, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x0F, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x07, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x03, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x87, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x07, 0xFE, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x3F, 0xFC, 0x03, 0xFC, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x7F, 0xFE, 0x07, 0xFC, 0x3E, 0x07, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x7F, 0xF8, 0x0F, 0xFE, 0x7F, 0xC7, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x7F, 0xF0, 0xFF, 0xFE, 0x7F, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xF8, 0xFF, 0xFC, 0xFF, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x7F, 0xFC, 0xFF, 0x1B, 0xFF, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0x7E, 0x37, 0xFF, 0xE7, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x1F, 0xFF, 0x81, 0xEF, 0xFF, 0x8F, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xFF, 0xFF, 0xDF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0xFE, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
  • 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  • void OledTask(void* arg)
  •     (void) arg;
  •     GpioInit();
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_13, WIFI_IOT_IO_FUNC_GPIO_13_I2C0_SDA);
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_14, WIFI_IOT_IO_FUNC_GPIO_14_I2C0_SCL);
  •     I2cInit(WIFI_IOT_I2C_IDX_0, OLED_I2C_BAUDRATE);
  •     ssd1306_Init();
  •     ssd1306_Fill(Black);
  •     ssd1306_DrawBitmap(bitmap, sizeof(bitmap));
  •     ssd1306_Refresh();
  •     HAL_Delay(2000);
  •     ssd1306_SetCursor(0, 0);
  •     ssd1306_DrawString(“Hello HarmonyOS!“, Font_7x10, White);
  • void OledExampleEntry(void)
  •     osThreadAttr_t attr;
  •     attr.name = “OledTask“;
  •     attr.attr_bits = 0U;
  •     attr.cb_mem = NULL;
  •     attr.cb_size = 0U;
  •     attr.stack_mem = NULL;
  •     attr.stack_size = 10240;
  •     attr.priority = osPriorityNormal;
  •     if (osThreadNew((osThreadFunc_t)OledTask, NULL, &attr) == NULL) {
  •         printf(“[OledExample] Falied to create OledTask!\n“);
  • SYS_RUN(OledExampleEntry);
复制代码 驱动实现: 六、编译 七、烧录 八、运行
下载附件  保存到相册
昨天 22:40 上传 九、总结
1)对比原理图,oled屏幕的I2C总线SDA引脚对应GPIO13,SCL引脚对应GPIO14。
下载附件  保存到相册
昨天 22:40 上传 修改源码,路径:vendor\hisi\hi3861\hi3861\app\wifiiot_app\init\app_io_init.c
下载附件  保存到相册
昨天 22:40 上传 2)开启I2C功能 修改文件:vendor\hisi\hi3861\hi3861\build\config\usr_config.mk
下载附件  保存到相册
昨天 22:42 上传 最后,感谢社区大佬们的总结贡献
