查看: 688|回复: 0
【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】第三篇 跑马灯
发表于 2020-11-15 23:56:46 | 显示全部楼层 |阅读模式
【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】第三篇 跑马灯, 弄了半天,VSCode中还是识别不了串口,只好放弃,采用Ubuntu中编译,Windows中使用HiBurn来烧写。
拿到开发板通常第一件事儿都是写个helloWorld的程序,点个灯
我也不例外,搞了个跑马灯。
代码如下:
LED_demo.c
  • #include <stdio.h>
  • #include <unistd.h>
  • #include “ohos_init.h“
  • #include “cmsis_os2.h“
  • #include “wifiiot_gpio.h“
  • #include “wifiiot_gpio_ex.h“
  • #define LED_TASK_STACK_SIZE 512
  • #define LED_TASK_PRIO 25
  • enum LedState {
  •     LED_ON = 0,
  •     LED_OFF,
  •     LED_SPARK,
  • static void *LedTask(const char *arg)
  •     (void)arg;
  •     while (1) {
  •         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 1);
  •         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
  •         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 0);
  •         usleep(300000);
  •         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 0);
  •         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 1);
  •         usleep(300000);
  •         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
  •         usleep(300000);
  •     return NULL;
  • static void led_demo(void)
  •     osThreadAttr_t attr;
  •     GpioInit();
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
  •     attr.name = “LedTask“;
  •     attr.attr_bits = 0U;
  •     attr.cb_mem = NULL;
  •     attr.cb_size = 0U;
  •     attr.stack_mem = NULL;
  •     attr.stack_size = LED_TASK_STACK_SIZE;
  •     attr.priority = LED_TASK_PRIO;
  •     if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL) {
  •         printf(“[LedExample] Falied to create LedTask!\n“);
  • SYS_RUN(led_demo);
复制代码 led_demo文件夹中
BIULD.gn
  • # Copyright (c) 2020 Huawei Device Co., Ltd.
  • # Licensed under the Apache License, Version 2.0 (the “License“);
  • # you may not use this file except in compliance with the License.
  • # You may obtain a copy of the License at
  • #     http://www.apache.org/licenses/LICENSE-2.0
  • # Unless required by applicable law or agreed to in writing, software
  • # distributed under the License is distributed on an “AS IS“ BASIS,
  • # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  • # See the License for the specific language governing permissions and
  • # limitations under the License.
  • static_library(“led_demo“) {
  •     sources = [
  •         “led_demo.c“
  •     include_dirs = [
  •         “//utils/native/lite/include“,
  •         “//kernel/liteos_m/components/cmsis/2.0“,
  •         “//base/iot_hardware/inteRFaces/kits/wifiiot_lite“,
复制代码 同时,也要将app文件夹中的编译脚本文件BUILD.gn修改一下,在features中添加以下内容:
“led_demo:led_demo“,
  • import(“//build/lite/config/component/lite_component.gni“)
  • lite_component(“app“) {
  •     features = [
  •         “startup“,
  •         “led_demo:led_demo“,
复制代码 添加完之后,返回CODE-1.0目录,在终端中输入以下命令:python build.py wifiiot
编译即可;
然后,返回Windows,用hiburn烧录即可。
第三篇完结,下一步,OLED,未完待续……
