查看: 731|回复: 0
鸿蒙应用:在线电子词典练习部分分享
发表于 2020-12-23 17:56:32 | 显示全部楼层 |阅读模式
鸿蒙应用:在线电子词典练习部分分享, 前期部分效果图
代码如下:
<?xml version=“1.0“ encoding=“utf-8“?>
<Directionallayout
     xmlns:ohos=“http://schemas.huawei.com/res/ohos“
     ohos:height=“match_parent“
     ohos:width=“match_parent“
     ohos:orientation=“vertical“>
   <DirectionalLayout
         ohos:left_margin=“200vp“
         ohos:right_margin=“200vp“
         ohos:top_margin=“20vp“
         <DirectionalLayout
             ohos:height=“50vp“
             ohos:orientation=“horizontal“>
             <TextField
                 ohos:id=“$+id:jltftextfield_word“
                 ohos:height=“match_content“
                 ohos:hint=“请输入要查询的单词“
                 ohos:background_element=“$graphic:border“
                 ohos:weight=“1“
                 ohos:padding=“4vp“
                 ohos:text_size=“30“/>
              <Button
                  ohos:id=“$+id:jltfbutton_search“
                  ohos:height=“30vp“
                  ohos:width=“100vp“
                  ohos:text=“搜索“
                  ohos:scale_mode=“zoom_center“/>
         </DirectionalLayout>
     <Text
         ohos:id=“$+id:jltftext_search_result“
         ohos:height=“200vp“
         ohos:multiple_lines=“true“
         ohos:visibility=“hide“
         ohos:top_margin=“10vp“
         ohos:text_alignment=“left|top“
         ohos:text_size=“20vp“
      <Image
          ohos:id=“$+id:jltfimage“
          ohos:weight=“1“
          ohos:image_src=“$media:index3“
提取本地词库
代码如下:
新建一个包一个类(电子词典类)
package com.example.jltfzidian.common;
import ohos.app.AbilityContext;
import ohos.global.resource.Resource;
import java.io.File;
import java.io.FileOutputStream;
import java.io.IOException;
import java.nio.file.Paths;
public class jltfmydict {
     private AbilityContext context;
     private File jltfdictpath;
     private  File jltfdbpath;
     public   jltfmydict(AbilityContext context){
         this.context = context;
         jltfdictpath = new File(context.getDatabaseDir().toString() +
                 “/MainAbility/databases/db“);
         if (!jltfdictpath.exists()){
             jltfdictpath.mkdirs();
         jltfdbpath = new
                 File(Paths.
get(jltfdbpath.toString(),“edictshujuku.sql“).toString());
     private void jltfextractdb() throws IOException{
         //读取edictshujuku.sql文件的字节流
         Resource resource =
                 context.getResourceManager().getRawFileEntry(“resoutces/rawfile/edictshujuku.sql“).openRawFile();
         if (jltfdbpath.exists()){
             jltfdbpath.delete();
         FileOutputStream jltffos = new FileOutputStream(jltfdbpath);
         byte[] jltfbuffer = new byte[4096];
         int count = 0;
         while ((count = resource.read(jltfbuffer))>= 0){
             jltffos.write(jltfbuffer,0,count);
         resource.close();
         jltffos.close();
     public void init() throws  IOException{
         jltfextractdb();
MainAbilitySlice中 添加如下代码
     mydict = new jltfmydict(this);
     try {
         mydict.init();
     }catch (IOException e){
         terminateAbility();
本练习参考了李宁老师公开的代码与课程。
