查看: 932|回复: 0
【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】感应灯Demo
发表于 2020-12-26 15:55:58 | 显示全部楼层 |阅读模式
【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】感应灯Demo, 分享一个比较简单的Demo
硬件模块:
HiSpark_WiFi_IoT_3861_CH340G_主板
HiSpark_WiFi_IoT_智能(炫彩)灯板
实现功能:
1.模拟红外人体感应灯,人到亮起红灯,人走红灯灭。
2.光敏电阻,暗环境亮绿灯,亮环境灭灯。
代码分享如下
1.在 applications\sample\wifi-iot\app\BUILD.gn 修改如下
  • import(“//build/lite/config/component/lite_component.gni“)
  • lite_component(“app“) {
  •     features = [
  •         “startup“,
  •         “sensor_light:sensor_light“,
复制代码
2.新建applications\sample\wifi-iot\app\sensor_light 目录并添加以下两个文件
applications\sample\wifi-iot\app\sensor_light\BUILD.gn
applications\sample\wifi-iot\app\sensor_light\sensor_light.c
3.applications\sample\wifi-iot\app\sensor_light\BUILD.gn  修改如下
  • static_library(“sensor_light“) {
  •     sources = [
  •         “sensor_light.c“
  •     include_dirs = [
  •         “//utils/native/lite/include“,
  •         “//kernel/liteos_m/components/cmsis/2.0“,
  •         “//base/iot_hardware/inteRFaces/kits/wifiiot_lite“,
复制代码
4.applications\sample\wifi-iot\app\sensor_light\sensor_light.c 修改如下
  • #include <stdio.h>
  • #include <unistd.h>
  • #include “ohos_init.h“
  • #include “cmsis_os2.h“
  • #include “wifiiot_gpio.h“
  • #include “wifiiot_gpio_ex.h“
  • #include “wifiiot_adc.h“
  • #include “wifiiot_errno.h“
  • static void SensorLightTask(void *arg)
  •     (void)arg;
  •     //人体感应ADC 值
  •     unsigned short humandata = 0;
  •     //光敏电阻ADC值
  •     unsigned short lightdata = 0;
  •     while(1){
  •         if (AdcRead(WIFI_IOT_ADC_CHANNEL_3, &humandata, WIFI_IOT_ADC_EQU_MODEL_4, WIFI_IOT_ADC_CUR_BAIS_DEFAULT, 0)
  •             == WIFI_IOT_SUCCESS) {
  •                 printf(“[SensorLight] humandata =%d\n“,humandata);
  •         if (AdcRead(WIFI_IOT_ADC_CHANNEL_4, &lightdata, WIFI_IOT_ADC_EQU_MODEL_4, WIFI_IOT_ADC_CUR_BAIS_DEFAULT, 0)
  •                 printf(“[SensorLight] lightdata =%d\n“,lightdata);
  •         //从串口log中来看ADC值感应到是18xx,没有感应到是12x,所以这里用500做一个阈值
  •         if(humandata > 500){
  •             GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_VALUE1);//R on
  •         }else{
  •             GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_VALUE0);//R off
  •         if(lightdata > 500){
  •             GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_VALUE1);//G on
  •         }else{
  •             GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_VALUE0);//G off
  •         usleep(10000);
  • static void SensorLight(void)
  •     osThreadAttr_t attr;
  •     GpioInit();
  •     //RLED init
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
  •     //GLED init
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
  •     //BLED init
  •     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
  •     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
  •     attr.name = “SensorLightTask“;
  •     attr.attr_bits = 0U;
  •     attr.cb_mem = NULL;
  •     attr.cb_size = 0U;
  •     attr.stack_mem = NULL;
  •     attr.stack_size = 4096;
  •     attr.priority = osPriorityNormal;
  •     if (osThreadNew(SensorLightTask, NULL, &attr) == NULL) {
  •         printf(“[SensorLight] Falied to create SensorLightTask!\n“);
  • SYS_RUN(SensorLight);
复制代码
站长推荐
