查看: 758|回复: 0
鸿蒙Hi3861小视频参赛:自家开发版上实现三色灯的变化
发表于 2020-12-26 17:56:09 | 显示全部楼层 |阅读模式
鸿蒙Hi3861小视频参赛:自家开发版上实现三色灯的变化, 这里使用的是hi3861 的三色灯板块,实现的是三色灯的变换,可以设置三色灯变换的次数,灯光变换的频率。 代码如下: #include<stdio.h> #include<unistd.h> #include “ohos_init.h“ #include “cmsis_os2.h“ #include “wifiiot_gpio.h“ #include “wifiiot_gpio_ex.h“ #include “wifiiot_pwm.h“ #include “wifiiot_adc.h“ #include “wifiiot_errno.h“ #define LED_DELAY_tiME_US 300000 #define LED_BRIGHT WIFI_IOT_GPIO_VALUE1 #define LED_DARK WIFI_IOT_GPIO_VALUE0 #define RED_LED_PIN_NAME WIFI_IOT_IO_NAME_GPIO_10 #define RED_LED_PIN_FUNCTION WIFI_IOT_IO_FUNC_GPIO_10_GPIO #define GREEN_LED_PIN_NAME WIFI_IOT_IO_NAME_GPIO_11 #define GREEN_LED_PIN_FUNCTION WIFI_IOT_IO_FUNC_GPIO_11_GPIO #define BLUE_LED_PIN_NAME WIFI_IOT_IO_NAME_GPIO_12 #define BLUE_LED_PIN_FUNCTION WIFI_IOT_IO_FUNC_GPIO_12_GPIO // 设置灯光的初始值 #define NUM_BLINKS 2 #define PWM_FREQ_DIVITION 64000 static void jltfcloudcom(void *arg) {     (void)arg;     IoSetFunc(RED_LED_PIN_NAME,WIFI_IOT_IO_FUNC_GPIO_10_PWM1_OUT);     IoSetFunc(GREEN_LED_PIN_NAME,WIFI_IOT_IO_FUNC_GPIO_11_PWM2_OUT);     IoSetFunc(BLUE_LED_PIN_NAME,WIFI_IOT_IO_FUNC_GPIO_12_PWM3_OUT);     PwmInit(WIFI_IOT_PWM_PORT_PWM1);     PwmInit(WIFI_IOT_PWM_PORT_PWM2);     PwmInit(WIFI_IOT_PWM_PORT_PWM3);     static const WifiIotGpioIdx pins[] = {RED_LED_PIN_NAME,GREEN_LED_PIN_NAME,BLUE_LED_PIN_NAME};     for(int i = 1 ; i <= NUM_BLINKS ; i++){          for(int i = 1 ; i <= PWM_FREQ_DIVITION ; i *= 2){            Pwmstart(WIFI_IOT_PWM_PORT_PWM1,i,PWM_FREQ_DIVITION);            usleep(250000);            PwmStop(WIFI_IOT_PWM_PORT_PWM1);        }         for(int i = 1 ; i <= PWM_FREQ_DIVITION ; i *= 2 ){            PwmStart(WIFI_IOT_PWM_PORT_PWM2,i,PWM_FREQ_DIVITION);             usleep(250000);             PwmStop(WIFI_IOT_PWM_PORT_PWM2);         }         for(int i = 1 ; i <= PWM_FREQ_DIVITION ; i *= 2){            PwmStart(WIFI_IOT_PWM_PORT_PWM3,i,PWM_FREQ_DIVITION);            usleep(250000);            PwmStop(WIFI_IOT_PWM_PORT_PWM3);        }         for(unsigned j = 0 ; j < sizeof(pins)/sizeof(pins[0]);j++){             GpioSetOutputVal(pins[j],LED_BRIGHT);             usleep(LED_DELAY_TIME_US);             GpioSetOutputVal(pins[j],LED_DARK);             usleep(LED_DARK);         }     }     } static void jltfcloudcn(void) {     osThreadAttr_t attr;     GpioInit();     attr.name=“jltfcloudcom“;     attr.attr_bits=0U;     attr.cb_mem=NULL;     attr.cb_size=0U;     attr.stack_mem=NULL;     attr.stack_size=4096;     attr.priority=osPriorityNormal;     if(osThreadNew(jltfcloudcom,NULL,&attr) == NULL){         printf(“[jltfcloudcn] Failed to create jltfcloudcom!\n“);     } } APP_FEATURE_INIT(jltfcloudcn); 以上功能实现,参考了网络上部分的公开代码。
