查看: 9726|回复: 16
中国PCB联盟网首发-Cadence16.6 HOTFIX VERSION: 015 (15号补丁)
发表于 2013-8-25 13:46:28 | 显示全部楼层 |阅读模式
Cadence16.6 HOTFIX VERSION: 015 (15号补丁)-中国PCB联盟网首发
* a! J3 x7 M: d8 E/ Y3 pDATE: 08-22-2013   HOTFIX VERSION: 015. h) S% Q& |! q. l/ ?. L
===================================================================================================================================. Z4 N* r% J5 ?
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
: E$ o3 V- R* d2 l0 s===================================================================================================================================
; s) T# y4 H( J( r# M" R9 }6 x1156102 pcb_LIBRARIAN  CORE             PDV severe performance degradation on Linux platform makes PDV counter productive after some time
1 u- j5 m8 W# b5 J2 s1165756 CONCEPT_HDL    CORE             DE HDL 16.6 adding ASCII character to properties
1 ?. e" N. a6 y4 }$ c1169896 ADW            LRM              Library Revision Manager makes updates but the interface never returns to the user' @/ \( j7 M2 [
1170635 SIP_layout     WIZARDS          BGA PIN NAME doesn't sync with PIN Number; `# K7 o% n  M
1171061 allegro_EDITOR PLACEMENT        Place Replicate Apply cannot place module
% h  a4 ?3 |; S7 b5 B, l$ \1171415 CONCEPT_HDL    CORE             Mismatch in the interface ports in design bw_hybrid for block a38410_scsp9 B$ i) H2 E" e
1171598 APD            WIREBOND         Cannot load xml over 65 profiles defined in file." I! [5 R& c2 U6 N% ~1 l+ B
1171713 ADW            LRM              Blank lines appear in the LRM - RM-Clicking causes LRM to crash
0 P7 K( X1 @3 q/ b/ f  i: F1172576 SIP_LAYOUT     IMPORT_DATA      AIF import fails with Error: symbol is missing refdes
7 l9 a; ]  i# G8 Q1172938 ALLEGRO_EDITOR PLOTTING         Export IPF probrem( t# L! u* b$ _/ c# ?
1173190 ALLEGRO_EDITOR ARTWORK          Not able to Add/ Replace film_setup.txt file in Artwork control file.
/ K( Z. T) @3 Y, C0 S/ _1173750 ALLEGRO_EDITOR REPORTS          SIP tool crash when clicking report "Net Loop Report"
2 W9 E4 ^; Q+ h+ I1175582 ALLEGRO_EDITOR SKILL            axlDBCreateFilmRec error undifined function
1 p! M$ W8 x. G! [1 L9 r4 A
发表于 2013-8-25 21:14:18 | 显示全部楼层
我的沙发 支持了+ K6 Z# K7 A# L- e, }9 {4 ]* m7 G
发表于 2013-8-25 21:29:20 | 显示全部楼层
回复一下,下载东西
发表于 2013-8-26 00:22:16 | 显示全部楼层
支持一下!
发表于 2013-8-28 16:40:05 | 显示全部楼层
更新了!3 q" {+ q7 s, v# ~9 }
发表于 2013-8-31 19:50:05 | 显示全部楼层
是不是那么好的啊
发表于 2013-9-2 17:03:58 | 显示全部楼层
谢谢楼主的辛苦分享
发表于 2017-1-31 18:59:31 | 显示全部楼层
好方法,学习下
发表于 2020-4-12 15:58:32 | 显示全部楼层
支持一下!
发表于 2020-6-18 17:16:57 | 显示全部楼层
有什么作用的补丁
