查看: 9176|回复: 1
[已解答问题] orcad原理图检查DRC时报警告WARNING(ORCAP-1600): Net has fewer than two connect...
发表于 2021-4-21 09:18:03 | 显示全部楼层 |阅读模式
orcad原理图检查DRC时报警告WARNING(ORCAP-1600): Net has fewer than two connect...N30775
怎么办?
*  Design Rules Check
Checking Schematic: EC200S-CN-Model
Checking Electrical Rules
Checking For Single Node Nets
WARNING(ORCAP-1600): Net has fewer than two connections N30775
Checking For Unconnected Bus Nets
Checking Physical Rules
Checking Pins and Pin Connections
INFO(ORCAP-2242): Checking Incorrect Pin Group Assignment
Report for Invalid References
Report for Duplicate References
Checking Entire Design: EC200S-CN-MODEL
INFO(ORCAP-2211): Check High Speed Properties Syntax
INFO(ORCAP-2212): Check Power Ground Mismatch
Reporting Unused Refdes in multiple part packages
Part                               Quantity                               Reference
我知道答案 回答被采纳将会获得5 联盟币 + 1 联盟币 已有1人回答
发表于 2021-7-6 09:47:40 | 显示全部楼层
单端网络,就是指这个网络没有连接到其它的地方,在原理图设计上需要检查核对一下,但是对网表的产生和导入是没有影响的。
