查看: 1720|回复: 1
[作业已审核] LaoFan 第三次作业 按键加减数码管
发表于 2021-4-29 22:49:35 | 显示全部楼层 |阅读模式
void SMG_TASK(void)
  static uint32_t count=0;
  static uint8_t step=0;
  switch(step)
  case 0:
      HAL_GPIO_WritePin(A1_GPIO_Port,A1_Pin,GPIO_PIN_SET);//打开位码
      HC595_WriteData(numTab[index]);//写入数据段
      step=1;
    break;
    case 1:
     count++;
     if(count>=500000)//延时
       count=0;
       step=0;
    break;
void HC595_WriteData(uint8_t data)
  HAL_GPIO_WritePin(RCK_GPIO_Port,RCK_Pin,GPIO_PIN_RESET);//关闭锁存器接口
  for(uint8_t i=0;i<8;i++)
    HAL_GPIO_WritePin(SCK_GPIO_Port,SCK_Pin,GPIO_PIN_RESET);//关闭串型时钟接口
    if(data&0x80)//1000 0000 先存低位后存高位
       HAL_GPIO_WritePin(DS_GPIO_Port,DS_Pin,GPIO_PIN_SET);//打开串型数据输入
    else
      HAL_GPIO_WritePin(DS_GPIO_Port,DS_Pin,GPIO_PIN_RESET);//关闭串型数据输入
    HAL_GPIO_WritePin(SCK_GPIO_Port,SCK_Pin,GPIO_PIN_SET);//打开串型时钟接口
    data=data<<1;
  HAL_GPIO_WritePin(RCK_GPIO_Port,RCK_Pin,GPIO_PIN_SET);//打开锁存器接口
static void TIME_TASK(void)
  count++;
  if(count>=100000)
    count=0;
    index++;
    index=index%10;
void KEY_UP_TASK(void)
  switch(step)
    case 0:
        if(HAL_GPIO_ReadPin( KEY_UP_GPIO_Port,KEY_UP_Pin)==GPIO_PIN_RESET)//判断是否按下按键
          count++;
          if(count>=8000)
            count=0;
              step=1;
        else
          count=0;
      break;
    case 1:
        if(HAL_GPIO_ReadPin( KEY_UP_GPIO_Port,KEY_UP_Pin)==GPIO_PIN_SET)//判断是否松开按键
          if(index<9)
            index++;
          else
            index=9;
          step=0;
      break;
void KEY_DOW_TASK(void)
  switch(step)
    case 0:
        if(HAL_GPIO_ReadPin( KEY_DOW_GPIO_Port,KEY_DOW_Pin)==GPIO_PIN_RESET)//判断是否按下按键
          count++;
          if(count>=8000)
            count=0;
              step=1;
        else
          count=0;
      break;
    case 1:
        if(HAL_GPIO_ReadPin( KEY_DOW_GPIO_Port,KEY_DOW_Pin)==GPIO_PIN_SET)//判断是否松开按键
          if(index>0)
            index--;
          else
            index=0;
          step=0;
      break;
1, 自己动手焊接能加深对电路的理解
2, 一开始对hc595的运行方式不了解一头雾水,查了点资料弄清楚工作模式后就很容易了
版主
发表于 2021-4-30 09:03:11 | 显示全部楼层
对的,通过动手焊接,学到印象深刻的东西,不错加油
