查看: 4047|回复: 1
[已解答问题] allegro17.2无法打开
发表于 2021-7-29 07:52:29 | 显示全部楼层 |阅读模式
软件打开弹窗,显示allegro Enterprise PCB Designer SuiteRetrieval of 'Allearo Enterprise PCB Designe' license failed: 'FRROR (LME-13015): License call failed for feature PCB Desian Studio. The license server search path is defined as snone>. The FLEXnet error message is as followsFLEXnet ERROR(-15, 234, 10061): Cannot connect to license server system.Run 'lic error LME-13015' for more information.. Report the licenses in use log via the menu item File->Viewlog: license use.log
发表于 2022-3-31 13:47:42 | 显示全部楼层
重新破解下
