查看: 2322|回复: 0
单片机C语言实例-107-按键 12864显示
发表于 2022-1-4 14:58:44 | 显示全部楼层 |阅读模式
内容:单个菜单,多页显示,不带子菜单
#include <reg52.h>
#include <intrins.h>
#include "delay.h"
sbit RS = P2^4;
sbit RW = P2^5;
sbit E  = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
#define DataPort P0        //单片机 P0<------> 液晶DB0-DB7
sbit KEY_ADD=P3^3;         //定义按键输入端口
sbit KEY_DEC=P3^4;
unsigned char curr,currold;//全局变量,当前箭头位置
unsigned char code user16x16[]={ //箭头图片
0x00,0x00,0x20,0x00,0x30,0x00,0x38,0x00,0x3C,0x00,0x3E,0x00,0x3F,0x00,0x3F,0x80,
0x3F,0xC0,0x3F,0x80,0x3F,0x00,0x3E,0x00,0x3C,0x00,0x38,0x00,0x30,0x00,0x20,0x00,
unsigned char code *MainMenu[]=
{"  1.设置1"},
{"  2.设置2"},
{"  3.设置3"},
{"  4.设置4"},
{"  5.设置5"},
{"  6.设置6"},
{"  7.设置7"},
{"  8.设置8"},
{"  9.设置9"},
{"  10. 设置10"},
                    检测忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙则等待
    E=0;
                   写命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    写数据
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延时程序
   PSB=1;                 //设置为8BIT并口工作模式
   DelayMs(1);            //延时
   RES=0;                 //复位
   DelayMs(1);            //延时
   RES=1;                 //复位置高
   DelayMs(10);
   Write_Cmd(0x30);       //选择基本指令集
   DelayUs2x(50);         //延时大于100us
   Write_Cmd(0x30);       //选择8bit数据流
   DelayUs2x(20);         //延时大于37us
   Write_Cmd(0x0c);       //开显示(无游标、不反白)
   Write_Cmd(0x01);       //清除显示,并且设定地址指针为00H
   DelayMs(15);           //延时大于10ms
   Write_Cmd(0x06);       //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
                   用户自定义字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
     for(i=0;i<16;i++)
            Write_Data(user16x16[i*2]);
        Write_Data(user16x16[i*2+1]);
                   显示用户自定义字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
    Write_Data(00);
    Write_Data(00);
                   显示字符串
x:横坐标值,范围0~8
y:纵坐标值,范围1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                   显示图片
/*void LCD_PutGraphic(unsigned char code *img)
int i,j;
//显示上半屏内容设置
   for(i=0;i<32;i++)
      Write_Cmd(0x80 + i); //SET  垂直地址 VERTICAL ADD
      Write_Cmd(0x80);     //SET  水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
//显示下半屏内容设置
   for(i=0;i<32;i++)
      Write_Cmd(0x88);     //SET 水平地址 HORIZONTAL ADD
      for(j=0;j<16;j++)
         Write_Data(*img);
         img++;
                 设置到绘图模式
/*void SetGraphicMode()
   Write_Cmd(0x36);       //选择8bit数据流 图形模式
   DelayUs2x(20);
                 调用显示更新
void DisplayUpdata(void)
    unsigned char num;
        ClrScreen();
        num=sizeof(MainMenu)/sizeof(MainMenu[0]);//判断数组中数值个数
        if((0+(curr/4)*4)<num)
      LCD_PutString(0,1,MainMenu[0+(curr/4)*4]);
        else //如果超出数组最大元素,则写空信息,不判断此信息可能会出现乱码
          LCD_PutString(0,1,"");
        if((1+(curr/4)*4)<num)
          LCD_PutString(0,2,MainMenu[1+(curr/4)*4]);
        else
          LCD_PutString(0,2,"");
        if((2+(curr/4)*4)<num)
          LCD_PutString(0,3,MainMenu[2+(curr/4)*4]);
        else
          LCD_PutString(0,3,"");
        if((3+(curr/4)*4)<num)
          LCD_PutString(0,4,MainMenu[3+(curr/4)*4]);
        else
          LCD_PutString(0,4,"");
        DisplayCGRAM(0,curr%4+1);
                 主程序
main()
  Init_ST7920();   //初始化
  CGRAM();     //写入自定义字符
  DisplayUpdata();
   while(1)
if(curr!=currold) //光标位置变化,则更新显示
    DisplayUpdata();
        currold=curr;
if(!KEY_ADD)  //如果检测到低电平,说明按键按下
         DelayMs(10); //延时去抖,一般10-20ms
     if(!KEY_ADD)     //再次确认按键是否按下,没有按下则退出
        while(!KEY_ADD);//如果确认按下按键等待按键释放,没有释放则一直等待
                   if(curr<sizeof(MainMenu)/sizeof(MainMenu[0])-1)//判断数组中数值个数
                          curr++;
if(!KEY_DEC)  //如果检测到低电平,说明按键按下
     if(!KEY_DEC)     //再次确认按键是否按下,没有按下则退出
        while(!KEY_DEC);//如果确认按下按键等待按键释放,没有释放则一直等待
               if(curr>0)
                          curr--;
更多详情参考附件文档
