查看: 2440|回复: 0
单片机C语言实例-140-外部频率测试
发表于 2022-1-19 13:55:07 | 显示全部楼层 |阅读模式
单片机C语言实例-140-外部频率测试
内容:
  引脚定义如下:1-VSS 2-VDD 3-V0 4-RS 5-R/W 6-E 7-14 DB0-DB7 15-BLA 16-BLK
#include "1602.h"
#include "delay.h"
#define CHECK_BUSY
sbit RS = P2^4;   //定义端口
sbit RW = P2^5;
sbit EN = P2^6;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
              判忙函数
bit LCD_Check_Busy(void)
#ifdef CHECK_BUSY
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
#else
return 0;
#endif
              写入命令函数
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙则等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
              写入数据函数
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
                清屏函数
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
              写入字符串函数
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
while (*s)
LCD_Write_Char(x,y,*s);
s ++;  x++;
              写入字符函数
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
        LCD_Write_Com(0x80 + x);
else
        LCD_Write_Com(0xC0 + x);
LCD_Write_Data( Data);
              初始化函数
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*显示模式设置*/
   DelayMs(5);
   DelayMs(5);
   DelayMs(5);
   LCD_Write_Com(0x08);    /*显示关闭*/
   LCD_Write_Com(0x01);    /*显示清屏*/
   LCD_Write_Com(0x06);    /*显示光标移动设置*/
   DelayMs(5);
   LCD_Write_Com(0x0C);    /*显示开及光标设置*/
更多详情参考附件文档
