查看: 3075|回复: 1
单片机C语言实例-373-24C08
发表于 2022-4-7 10:22:15 | 显示全部楼层 |阅读模式
单片机C语言实例-373-24C08
//24c08地址为0xa0
#include <reg52.h>
#define uchar unsigned char
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char sec=0; //定义计数值,每过1秒,sec加1
unsigned int count; //定时中断次数
bit  write=0; //写24C08的标志;
sbit gewei=P2^7; //个位选通定义
sbit shiwei=P2^6; //十位选通定义
/////////24C08读写驱动程序////////////////////
sbit scl=P3^4; // 24c08 SCL
sbit sda=P3^5; // 24c08 SDA
sbit K5=P1^4;  //清0按键
void delay()   //delay 5us
void delay1(uchar x)
        uchar a,b;
        for(a=x;a>0;a--)
         for(b=100;b>0;b--);
void start()  //开始信号
        sda=1;
        delay();
        scl=1;
        delay();
        sda=0;
        delay();
void stop()   //停止信号
        sda=0;
        delay();
        scl=1;
        delay();
        sda=1;
        delay();
void respons()  //应答
        uchar i;
        scl=1;
        delay();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay();
void init_24c08()  //初始化24C02
        sda=1;
        delay();
        scl=1;
        delay();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
            delay();
                sda=CY;
                delay();
                scl=1;
                delay();
        //        scl=0;
     // delay();
        scl=0;
        delay();
        sda=1;
        delay();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay();
        sda=1;
        delay();
        for(i=0;i<8;i++)
                scl=1;
                delay();
                k=(k<<1)|sda;
                scl=0;
                delay();
        return k;
void write_24c08(uchar address,uchar shuju) //给指定地址中写入数据
        start();
        write_byte(0xa0);    //  最低位为0写,1读
        respons();
        write_byte(address);
        respons();
        write_byte(shuju);
        respons();
        stop();
uchar read_24c08(uchar address) //从24c08指定地址中读出数据
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        return date;
/////////////24C02读写驱动程序完/////////////////////
void LEDshow() //LED显示函数
    P0=table[sec/10];
    shiwei=0;
        delay1(40);
        shiwei=1;
        P0=table[sec%10];
    gewei=0;
        delay1(40);
        gewei=1;
void main(void)
        TMOD=0x01; //定时器工作在方式1
        ET0=1;
    EA=1;
        init_24c08(); //初始化24C08
        sec=read_24c08(2);//读出保存的数据赋于sec
        TH0=(65536-50000)/256; //对TH0 TL0赋值
        TL0=(65536-50000)%256; //使定时器0.05秒中断一次
        TR0=1; //开始计时
                while(1)
                    LEDshow();
                        if(write==1) //判断计时器是否计时一秒
                        write=0; //清零
                        write_24c08(2,sec); //在24c08的地址2中写入数据sec
                  if(K5==0){
                          delay1(10);
                        if(K5==0){
                         sec=0;
void t0(void) interrupt 1 using 0 //定时中断服务函数
        TL0=(65536-50000)%256; //重装计数初值
        count++; //每过50ms tcnt加一
        if(count==20) //计满20次(1秒)时
                count=0; //重新再计
                sec++;
                write=1; //1秒写一次24C08
                if(sec==100) //定时100秒,在从零开始计时
                {sec=0;}
更多详情参考附件文档
发表于 2022-4-7 20:33:32 | 显示全部楼层
666666666666666666666
