查看: 2395|回复: 0
单片机C语言实例-376-18B20
发表于 2022-4-7 10:26:28 | 显示全部楼层 |阅读模式
单片机C语言实例-376-18B20
#include < reg51.h >
#include < intrins.h >
#define uchar unsigned char
#define uint  unsigned int
sbit DQ = P3^3 ;  //定义DS18B20端口DQ
sbit BEEP=P3^6  ; //蜂鸣器驱动线
bit presence  ;          //检测18b20是否插好
sbit LCD_RS = P2^0 ;
sbit LCD_RW = P2^1 ;
sbit LCD_EN = P2^2 ;
uchar code  cdis1[ ] = {" WWW.RICHMCU.COM "} ;
uchar code  cdis2[ ] = {" WENDU:    .  C "} ;
uchar code  cdis3[ ] = {" DS18B20  ERR0R "} ;
uchar code  cdis4[ ] = {"  PLEASE CHECK  "} ;
unsigned char data  temp_data[2] = {0x00,0x00} ;
unsigned char data  display[5] =   {0x00,0x00,0x00,0x00,0x00} ;
unsigned char code  ditab[16] =    {0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,
                                                        0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09} ;
void beep() ;
unsigned char code  mytab[8] = {0x0C,0x12,0x12,0x0C,0x00,0x00,0x00,0x00} ;
#define delayNOP() ; {_nop_() ;_nop_() ;_nop_() ;_nop_() ;} ;
void delay1(int ms)
unsigned char y ;
  while(ms--)
  for(y = 0 ; y<250 ; y++)
   _nop_() ;
   _nop_() ;
   _nop_() ;
   _nop_() ;
/*检查LCD忙状态                                                   */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。   */
bit lcd_busy()
    bit result ;
    LCD_RS = 0 ;
    LCD_RW = 1 ;
    LCD_EN = 1 ;
    delayNOP() ;
    result = (bit)(P0&0x80) ;
    LCD_EN = 0 ;
    return(result) ;
/*写指令数据到LCD                                                  */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。          */
void lcd_wcmd(uchar cmd)
   while(lcd_busy()) ;
    LCD_RS = 0 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    _nop_() ;
    _nop_() ;
    P0 = cmd ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*写显示数据到LCD                            */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。       */
void lcd_wdat(uchar dat)
   while(lcd_busy()) ;
    LCD_RS = 1 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    P0 = dat ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*  LCD初始化设定                                                  */
void lcd_init()
    delay1(15) ;
    lcd_wcmd(0x01) ;      //清除LCD的显示内容
    lcd_wcmd(0x38) ;      //16*2显示,5*7点阵,8位数据
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x0c) ;      //显示开,关光标
    delay1(5) ;
    lcd_wcmd(0x06) ;      //移动光标
    delay1(5) ;
    delay1(5) ;
/*  设定显示位置                                    */
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80) ;  //数据指针=80+地址变量
/*unsigned char data  temp_data[2] = {0x00,0x00} ;
void beep() ;
unsigned char code  mytab[8] = {0x0C,0x12,0x12,0x0C,0x00,0x00,0x00,0x00} ;*/
/*自定义字符写入CGRAM                                   */
void  writetab()
    unsigned char i ;
    lcd_wcmd(0x40) ;            //写CGRAM
    for (i = 0 ; i< 8 ; i++)
    lcd_wdat(mytab[ i ]) ;
/*us级延时函数                                        */
void Delay(unsigned int num)
  while( --num ) ;
/*初始化ds1820                                      */
Init_DS18B20(void)
     DQ = 1 ;      //DQ复位
     Delay(8) ;    //稍做延时
     DQ = 0 ;      //单片机将DQ拉低
     Delay(90) ;   //精确延时 大于 480us
     DQ = 1 ;       //拉高总线
     Delay(8) ;
     presence = DQ ;    //如果=0则初始化成功 =1则初始化失败
     Delay(100) ;
     DQ = 1 ;
     return(presence) ; //返回信号,0=presence,1= no presence
/* 读一个字节                     */
ReadOneChar(void)
unsigned char i = 0 ;
unsigned char dat = 0 ;
for (i = 8 ; i > 0 ; i--)
    DQ = 0 ; // 给脉冲信号
    dat >>= 1 ;
    DQ = 1 ; // 给脉冲信号
    if(DQ)
     dat |= 0x80 ;
    Delay(4) ;
    return (dat) ;
/* 写一个字节                                         */
WriteOneChar(unsigned char dat)
    DQ = 0 ;
    DQ = dat&0x01 ;
    Delay(5) ;
    DQ = 1 ;
    dat>>=1 ;
/* 读取温度                            */
Read_Temperature(void)
     Init_DS18B20() ;
     WriteOneChar(0xCC) ;  // 跳过读序号列号的操作
     WriteOneChar(0x44) ;  // 启动温度转换
     Init_DS18B20() ;
     WriteOneChar(0xCC) ;  //跳过读序号列号的操作
     WriteOneChar(0xBE) ;  //读取温度寄存器
     temp_data[0] = ReadOneChar() ;   //温度低8位
     temp_data[1] = ReadOneChar() ;   //温度高8位
/* 数据转换与温度显示                                              */
Disp_Temperature()
{ // 温度高8位SSSS Sb1b2b3    温度低8位b4b5b6b7 x1x2x3x4
//高8位前5位是符号位,紧接着b1b2b3b4b5b6b7是整数部分,x1x2x3x4位小数部分
  display[4]=temp_data[0]&0x0f ;//取温度低8位的低4位(小数位)
  display[0]=ditab[display[4]]+0x30 ;//查表得小数位的值        //+0x30是转换成IC码
  display[4]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4) ;//整数部分取值
  display[3]=display[4]/100+0x30 ; //求商得百位值(显示)
  display[1]=display[4]%100 ; //求余得到十位个位数据
  display[2]=display[1]/10+0x30 ;//得到十位数据(显示)
  display[1]=display[1]%10+0x30 ;//得到个位数据(显示)
    if(display[3]==0x30)        //高位为0,不显示
     display[3]=0x20 ;
     if(display[2]==0x30)      //次高位为0,不显示
     display[2]=0x20 ;
     lcd_pos(0x48) ;
     lcd_wdat(display[3]) ;        //百位数显示
     lcd_pos(0x49) ;
     lcd_wdat(display[2]) ;        //十位数显示
  lcd_pos(0x4a) ;
     lcd_wdat(display[1]) ;        //个位数显示
  lcd_pos(0x4c) ;
     lcd_wdat(display[0]) ;        //小数位数显示
/* 蜂鸣器响一声                 */
void beep()
    unsigned char y ;
    for (y=0 ;y<100 ;y++)
      Delay(60) ;
      BEEP=!BEEP ;                //BEEP取反
    BEEP=1 ;                      //关闭蜂鸣器
Delay(40000) ;
/*uchar code  cdis1[ ] = {" WWW.RICHMCU.COM "} ;
uchar code  cdis4[ ] = {"  PLEASE CHECK  "} ; */
/* DS18B20 OK 显示菜单                                             */
void  Ok_Menu ()
    uchar  m ;
    lcd_init() ;                //初始化LCD
    lcd_pos(0) ;                //设置显示位置为第一行的第1个字符
     m = 0 ;
    while(cdis1[m] != '\0')
     {                         //显示字符
       lcd_wdat(cdis1[m]) ;
       m++ ;
    lcd_pos(0x40) ;             //设置显示位置为第二行第1个字符
     m = 0 ;
    while(cdis2[m] != '\0')
       lcd_wdat(cdis2[m]) ;      //显示字符
       m++ ;
     writetab() ;               //自定义字符写入CGRAM
     delay1(5) ;
     lcd_pos(0x4d) ;
     lcd_wdat(0x00) ;          //显示自定义字符
/* DS18B20 ERROR 显示菜单                             */
void  Error_Menu ()
     uchar  m ;
     m = 0 ;
     while(cdis3[m] != '\0')
     {                         //显示字符
       lcd_wdat(cdis3[m]) ;
       m++ ;
     m = 0 ;
     while(cdis4[m] != '\0')
       lcd_wdat(cdis4[m]) ;      //显示字符
       m++ ;
/* 主函数     */
void main()
     Ok_Menu () ;
do
    Read_Temperature() ; //读取温度
   Disp_Temperature() ;         //显示温度
    while(!presence)  ;
     Error_Menu () ;
do
    Init_DS18B20() ;
    beep() ;
while(presence) ;
更多详情参考附件文档
