查看: 2674|回复: 0
单片机C语言实例-385-PCF8591 DA转换实验
发表于 2022-4-12 11:02:08 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#include <string.h>
#define uchar unsigned char
#define uint  unsigned int
#define disdata  P0              //显示数据码输出口
bit flag;
sbit SCL=P3^4;                   // 将p1.0口模拟时钟口
sbit SDA=P3^5;                   // 将p1.3口模拟数据口
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
sbit  K1   = P1^4;
sbit  K2   = P1^5;       //选择健
sbit  K3   = P1^6;       //启动健
sbit  K4   = P1^7;       //停止健
sbit  BEEP = P3^6;       //蜂鸣器
uchar code dis1[] = {"    PCF-8591    "};
uchar code dis2[] = {"  DA CONVERTER  "};
uchar code dis3[] = {" K2: D/A CHOOSE "};
uchar code dis4[] = {"K3:ENTER K4:EXIT"};
uchar code dis5[] = {"   SINE  WAVE   "};
uchar code dis6[] = {"  SQUARE  WAVE  "};
uchar code dis7[] = {" TRIANGLE  WAVE "};
uchar code dis8[] = {" SAWTOOTH  WAVE "};
bit  out1=0,out2=0,out3=0,out4=0,START=0;
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
bit   bdata SystemError;                //从机错误标志位
uchar N=0x00,k_count;
/*********************** PCF8591专用变量定义 ***********************/
#define        PCF8591_WRITE        0x90
#define        PCF8591_READ         0x91
#define  NUM  4                     //接收和发送缓存区的深度
uchar idata receivebuf[NUM];    //数据接收缓冲区
uchar  code  sin_tab[] =        //正弦波输出表
     0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
     0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
     0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
     0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
     0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
     0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,0xDA,
     0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
     0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
     0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
     0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
     0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
     0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
     0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
     0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
     0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
     0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C,0x7E
/*  延时函数                                                       */
void delayB(uchar x)    //x*0.14MS
   uchar i;
   while(x--)
     for (i=0; i<13; i++)
/*  延时函数                                                       */
void delay(int ms)
    while(ms--)
      uchar i;
          for(i=0;i<250;i++)
            _nop_();
            _nop_();
            _nop_();
            _nop_();
/*  蜂鸣器函数                                                     */
void beep()
   uchar j;
   for (j=0;j<180;j++)
     delayB(5);
     BEEP=!BEEP;                 //BEEP取反
     BEEP=1;                    //关闭蜂鸣器
         delay(100);
/*检查LCD忙状态                                                    */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。      */
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*写指令数据到LCD                                                  */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。                             */
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*写显示数据到LCD                                                  */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。                               */
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*  LCD初始化设定                                                  */
void lcd_init()
    delay(15);
    lcd_wcmd(0x38);      //16*2显示,5*7点阵,8位数据
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x0c);      //显示开,关光标
    delay(5);
    lcd_wcmd(0x06);      //移动光标
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的显示内容
    delay(5);
/*  设定显示位置                                                   */
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80);  //数据指针=80+地址变量
// 函数名称: iic_start()
// 函数功能: 启动I2C总线子程序
void iic_start(void)
{ //时钟保持高,数据线从高到低一次跳变,I2C通信开始
        SDA = 1;
        SCL = 1;
        delayNOP();      // 延时5us
           SDA = 0;
        delayNOP();
    SCL = 0;
// 函数名称: iic_stop()
// 函数功能: 停止I2C总线数据传送子程序
void iic_stop(void)
        SDA = 0;              //时钟保持高,数据线从低到高一次跳变,I2C通信停止
        SCL = 1;
        delayNOP();
        SDA = 1;
        delayNOP();
    SCL = 0;
// 函数名称: iicInit_()
// 函数功能: 初始化I2C总线子程序
void iicInit(void)
   SCL = 0;
   iic_stop();
// 函数名称: slave_ACK
// 函数功能: 从机发送应答位子程序
void slave_ACK(void)
        SDA = 0;
        SCL = 1;
        delayNOP();
        SCL = 0;
// 函数名称: slave_NOACK
// 函数功能: 从机发送非应答位子程序,迫使数据传输过程结束
void slave_NOACK(void)
        SDA = 1;
        SCL = 1;
        delayNOP();
        SDA = 0;
    SCL = 0;
// 函数名称: check_ACK
// 函数功能: 主机应答位检查子程序,迫使数据传输过程结束
void check_ACK(void)
    SDA = 1;        // 将p1.1设置成输入,必须先向端口写1
        SCL = 1;
        flag = 0;
        delayNOP();
        if(SDA == 1)    // 若SDA=1表明非应答,置位非应答标志flag
    flag = 1;
           SCL = 0;
// 函数名称: IICSendByte
// 入口参数: ch
// 函数功能: 发送一个字节
void IICSendByte(uchar ch)
          unsigned char idata n=8;     // 向SDA上发送一位数据字节,共八位
        while(n--)
        if((ch&0x80) == 0x80)    // 若要发送的数据最高位为1则发送位1
                         SDA = 1;    // 传送位1
                        SCL = 1;
                    delayNOP();
                //        SDA = 0;
                        SCL = 0;
                else
                        SDA = 0;    // 否则传送位0
                        SCL = 1;
                        delayNOP();
                          SCL = 0;
                ch = ch<<1;    // 数据左移一位
// 函数名称: IICreceiveByte
// 返回接收的数据
// 函数功能: 接收一字节子程序
uchar IICreceiveByte(void)
        uchar idata n=8;     // 从SDA线上读取一上数据字节,共八位
        uchar tdata=0;
        while(n--)
           SDA = 1;
           SCL = 1;
           tdata =tdata<<1;                    //左移一位
                   if(SDA == 1)
                  tdata = tdata|0x01;   // 若接收到的位为1,则数据的最后一位置1
                else
                  tdata = tdata&0xfe;   // 否则数据的最后一位置0
           SCL = 0;
         return(tdata);
// 函数名称: DAC_PCF8591
// 入口参数: slave_add从机地址,n要发送的数据个数
// 函数功能: 发送n位数据子程序
void DAC_PCF8591(uchar controlbyte)
        iic_start();                    // 启动I2C
        delayNOP();
        IICSendByte(PCF8591_WRITE);     // 发送地址位
        check_ACK();                    // 检查应答位
    if(flag == 1)
                SystemError = 1;
                return;                     // 若非应答,置错误标志位
    IICSendByte(controlbyte&0x77);        //Control byte
        check_ACK();                    //检查应答位
    if(flag == 1)
                SystemError = 1;
// 函数名称: ADC_PCF8591
// 入口参数: controlbyte控制字
// 函数功能: 连续读入4路通道的A/D转换结果到receivebuf
void ADC_PCF8591(uchar controlbyte)
    uchar idata i; //,receive_da;
        iic_start();
        IICSendByte(PCF8591_WRITE);        //控制字
        check_ACK();
        if(flag == 1)
                SystemError = 1;
                return;
        IICSendByte(controlbyte);        //控制字
        check_ACK();
        if(flag == 1)
                SystemError = 1;
                return;
    iic_start();                //重新发送开始命令
           IICSendByte(PCF8591_READ);        //控制字
        check_ACK();
        if(flag == 1)
                SystemError = 1;
                return;
    IICreceiveByte();   //空读一次,调整读顺序
    slave_ACK();        //收到一个字节后发送一个应答位
//        while(i<4)
            for(i=0;i<4;i++)
        //  receive_da=IICreceiveByte();
        //  receivebuf=receive_da;
      receivebuf = IICreceiveByte();
        slave_NOACK();       //收到最后一个字节后发送一个非应答位
        iic_stop();
  输出三角波
void  Triangle()
    uchar l;
    for(l=0;l<255;l++)
           IICSendByte(l);               //data byte
       if(flag == 1)
                SystemError = 1;
            return;               //置错误标志位SystemError
      for(l=255;l>1;l--)
       if(flag == 1)
                SystemError = 1;
  输出方波函数
void  Square()
     IICSendByte(N);             //data byte
     if(flag == 1)
           SystemError = 1;
      delay(15);
          N=~N;
  输出正弦波函数
void  sin()
  uint i;
  for(i=0; i<256; i++)
    IICSendByte(sin_tab);          //data byte
    if(flag == 1)
           SystemError = 1;
  输出锯齿波函数
void  Sawtooth()
  uchar l;
    for(l=0;l<255;l++)
       if(flag == 1)
                SystemError = 1;
  功能健函数
void  keyscan()
   uchar m;
   if((K2==0)&(!START))       //启动输出后,屏蔽K2健
     k_count++;
     beep();
     switch (k_count)
        case 1:
        lcd_pos(0x00);
            for(m=0;m<16;m++)
        lcd_wdat(dis2[m]);
        lcd_pos(0x40);
            for(m=0;m<16;m++)
        lcd_wdat(dis5[m]);
        out1=1;
                out4=0;
        break;
        case 2:
        lcd_pos(0x40);
            for(m=0;m<16;m++)
        lcd_wdat(dis6[m]);
        out1=0;
                out2=1;
        break;
                case 3:
        lcd_pos(0x40);
            for(m=0;m<16;m++)
        lcd_wdat(dis7[m]);
                out2=0;
                out3=1;
        break;
        case 4:
        lcd_pos(0x40);
            for(m=0;m<16;m++)
        lcd_wdat(dis8[m]);
        k_count=0;
        out3=0;
                out4=1;
        break;
        default:
        out4=0; out3=0; out2=0; out1=0;
        break;
    if(K3==0)        //启动输出
           START=1;
           beep();
        if(K4==0)       //停止输出
           START=0;
           beep();
/*  主函数                                                         */
main()
    uchar i;
    delay(10);                 //延时
    lcd_init();                //初始化LCD
    lcd_pos(0);                //设置显示位置为第一行
    for(i=0;i<16;i++)
    lcd_wdat(dis1);         //显示字符
    lcd_pos(0x40);             //设置显示位置为第二行
    for(i=0;i<16;i++)
    lcd_wdat(dis2);         //显示字符
    delay(1500);
    for(i=0;i<16;i++)
    lcd_wdat(dis3);         //显示字符
    for(i=0;i<16;i++)
    lcd_wdat(dis4);         //显示字符
        DAC_PCF8591(0x40);
        while(1)
           keyscan();
           while(out1&START)
         sin();              //输出正弦波
         keyscan();
       while(out2&START)
         Square();           //输出方波
         keyscan();
           while(out3&START)
         Triangle();        //输出三角波
         keyscan();
            while(out4&START)
         Sawtooth();        //输出锯齿波
         keyscan();
更多详情参考附件文档
