查看: 1141|回复: 1
QCA9882-802.11ac-Mini-PCIe-WiFi-Module-5G-wallys/network card
发表于 2022-4-14 11:31:05 | 显示全部楼层 |阅读模式
QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024/QCA9531
Featuring with industrial-grade Atheros’s  chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
QCA9882
QCA9882
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    3.3V(MINIPCIE)
    V
    Operating Temperature Range
    -40 to +60
    oC
    Storage Temperature Range
    -65 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    QCA9882
    Antenna Connector
    2 x 5G MMCX connectors
    ROHS Compliance
    YES
    Dimension
    50mm x 30mm x 16mm
    Radio TX Specifications
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    802.11a
    6 Mbps
    25dBm
    28dbm
    ±2dB
    54 Mbps
    21dBm
    24dbm
    ±2dB
    802.11n HT20
    MCS0, MCS8
    25dBm
    28dbm
    ±2dB
    MCS7, MCS15
    20dBm
    23dbm
    ±2dB
    802.11n HT40
    MCS0, MCS8
    25dBm
    28dbm
    ±2dB
    MCS7, MCS15
    20dBm
    23dbm
    ±2dB
    802.11ac
    MCS0, MCS10,MCS20
    25dBm
    28dbm
    ±2dB
    MCS9,MCS19,MCS29
    17dBm
    20dbm
    ±2dB
    Radio RX Specifications
    Operating Mode
    Data Rate
    Sensitivity
    802.11a
    6 Mbps
    -96dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -92dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
发表于 2022-4-17 21:52:08 | 显示全部楼层
what are you talking about
