查看: 2053|回复: 0
单片机C语言实例-395-原创VB串口继电器控制实验
发表于 2022-4-18 10:21:39 | 显示全部楼层 |阅读模式
//按K1 继电器吸合
//按K2 继电器断开
#include <reg52.h>
sbit  K1 =P3^2 ;                    //K1
sbit  K2 =P3^3 ;                    //K2
sbit JDQ=P3^7;                                           //继电器
unsigned char inbuf2[5];//接收缓冲区
unsigned char count3;
void init_serialcomm( void )
SCON = 0x50 ; //SCON: serail mode 1, 8-bit UART, enable ucvr
TMOD |= 0x20 ; //TMOD: timer 1, mode 2, 8-bit reload
PCON |= 0x80 ; //SMOD=1;
TH1 = 0xFA ; //Baud:4800 fosc=11.0592MHz
IE |= 0x90 ; //Enable Serial Interrupt
TR1=1;
//串口接收中断函数
void serial () interrupt 4 using 3
if (RI) //RI==开始接收
unsigned char ch;
RI = 0 ; //软件RI=0
ch=SBUF;
if (ch>1)
count3= 0 ;
inbuf2[count3]=ch;
else
count3++;
inbuf2[count3]=ch;
void Delay(unsigned int ii)        //1MS
unsigned int jj;
for(;ii>0;ii--)
for(jj=0;jj<125;jj++)
void main()
{  init_serialcomm();
JDQ=0;
   EA = 1;                                        //允许CPU中断
   while(1){
            if (inbuf2[0]==0x31){
         JDQ=1;//吸合
P0=0x00;//P0口LED亮
         if (inbuf2[0]==0x32){
         JDQ=0;//吸合
P0=0xff;//P0口LED亮
   if (K1==0)
Delay(10);
if(K1==0){
inbuf2[0]=0x00;
JDQ=1;//吸合
P0=0x00;//P0口LED亮
if (K2==0){
Delay(10);
if(K2==0){
inbuf2[0]=0x00;
         JDQ=0;        //释放
         P0=0xff; //P0口LED灯灭
更多详情参考附件文档
