查看: 1171|回复: 0
DR24-RUBBER-ANTENNA-2.4G-SMA-SATA-COMINATION-3DBI-6DBI-wallys
发表于 2022-4-20 10:56:23 | 显示全部楼层 |阅读模式
dipole Antenna/panel antenna/smart antenna/omni antenna
Advantages of the product
High Gain
Small Standing Wave Radio
Signal Stabilization
Environmental Protection Material
Application of the product
Wireless Monitoring
WIFI
ZIGBEE
Bluetooth Module
Smart Home
Product Signal Lamp and Other Transmission Equipment
    Product Name
    Rubber antenna(2.4G)+SMA SATA Combination
    Frequency Range
    2400-2500mhz
    Gain
    3DBI/6DBI
    Transfer Wire
    RG1.13
    Power
    50W
    Impedance
    50ohm
    Application
    Wireless Monitoring   WIFI   ZIGBEE   Bluetooth Module
    Total Height
    19.5cm/11cm
    Polarization
    Vertical Polarization
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
