查看: 2886|回复: 1
OpenWRT QCN9074 WiFi Card IPQ6010/IPQ6018/IPQ6000 802.11ax 2x2 2.4G&5G
发表于 2022-4-24 14:03:11 | 显示全部楼层 |阅读模式
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
    SD Card Slot
    1x SD Card Slot(Option)
    USB /header
    1x USB 3.0 Port(Option)
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V~48V power supply
    LED header
    2.0 pitch pin header
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Nor Flash
    8MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    125mm x 105mm x 20mm
      Boot_Config Switch1(S7)
      Boot_Config
      Boot up InterfaceSelect
      S7A
      S7B
      S7C
      SPI NOR. (Default)
      eMMC
      QPIC, Parallel NAND
      USB3.0
      SPI-NOR-GPT
      S7D
      Boot from code ram.(Default)
      Boot from ROM
      Boot_Config Switch2(S9)
      Boot_Config
      No auth.(Default)
      Auth is required
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
发表于 2022-5-9 19:13:58 | 显示全部楼层
谢谢分享!
举报
