查看: 1538|回复: 0
QCA9880/QCA9882 802.11ac 3x3 2.4G/5G FCC/CE/IC-wallys
发表于 2022-5-7 14:35:06 | 显示全部楼层 |阅读模式
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
    Symbol
    Parameter
    Chipset
    QCA9880
    Host Interface
    Mini PCI Express 1.1 Standard
    Antenna Connector
    3 x UF.L
    Frequency Range
    2.4GHz: 2.412GHz to 2.472GHz
    5GHz: 4.920GHz to 5.825GHz
    Operating Voltage
    3.3V DC
    Power Consumption
    5W(Max)
    Modulation Techniques
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
    Environmental Temperature
    Operating: -40°C to 70°C, Storage: -40°C to 90°C
    Environmental Humidity, non-condensing
    Operating: 5% to 95%, Storage: Max. 90%
    ROHS Compliance
    YES
    Dimensions (W×H×D)
    30.0mm × 50.9mm × 3.2mm
    GPIO Pin
    Function
    GPIO0
    WLAN_DIS
    GPIO1
    WLAN_LED
    GPIO2
    MCI_CLK_IN
    GPIO3
    MCI_CLK_OUT
    GPIO4
    MCI_DATA_OUT
    GPIO5
    MCI_DATA_IN
    GPIO12
    TMS
    13
    TCK
    14
    TDI
    15
    TDO
    16
    CPU_WARM_RESET / JTEG RESET
    17
    GPIO17_BT_LED
    19
    ANT_A
    20
    ANT_B
    21
    FEM_BS
    22
    FEM_MODE
    MiniPCIe Slot Pin Assignment
    TOP Side
    Bottom Side
    PCIE_WAKE_L
    VCC_3V3
    NC
    4
    GND
    5
    NC
    6
    NC
    7
    PCIE_CLKREQ_L
    8
    NC
    9
    GND
    10
    NC
    11
    PCIE_REFCLK_N
    12
    NC
    13
    PCIE_REFCLK_P
    14
    NC
    15
    GND
    16
    NC
    Mechanical key
    17
    NC
    18
    GND
    19
    NC
    20
    GPIO0_WLAN_DIS
    21
    GND
    22
    PCIE_RST_L
    23
    PCIE_TX_N
    24
    VCC_3V3
    25
    PCIE_TX_P
    26
    GND
    27
    GND
    28
    NC
    29
    GND
    30
    NC
    31
    PCIE_RX_P
    32
    NC
    33
    PCIE_RX_N
    34
    GND
    35
    GND
    36
    NC
    37
    GND
    38
    NC
    39
    VCC_3V3
         (RESERVED)
    40
    GND
    41
    VCC_3V3
         (RESERVED)
    42
    NC
    43
    GND
    44
    GPIO1_WLAN_LED
    45
    NC
    46
    GPIO17_BT_LED
    47
    NC
    48
    NC
    49
    NC
    50
    GND
    51
    NC
    52
    VCC_3V3
      Version
    Version
    CPU
    Feature
    DR900VX
    QCA9880
    DR900VX-i
    QCA9890
    Operation Temp. Up to 85°
    DR900VX-4.9
    QCA9880
    Support 4.9G
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
    QCA9880
    QCA9880
