查看: 2102|回复: 0
QCN9074 QCN9024 QCN6024 802.11ax 4x4 MU-MIMO 5GHz wifi6-wallys
发表于 2022-5-24 10:01:27 | 显示全部楼层 |阅读模式
■ Qualcomm Atheros QCN9074
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 WiFi 6 (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
■ Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to 70
    oC
    Storage Temperature Range
    -40 to 90
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    Chipset
    WLAN Host Interface
    System Memory
    2Mbit serial I2C bus EEPROM
    Standard Operating Voltage
    5V
    Operating Systems
    QSDK
    Host Interface
    M.2 E Key
    Antenna Cable / Port
    4 x MMCX Connectors,4T4R
    Frequency Range
    5.15GHz-5.95GHz
    Data Rates for WALN
    Channel Spectrum Widths for WLAN
    Support 20/40/80/160MHz at 5GHz
    Modulation Techniques
    OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
    Temperature Range
    Operating: -20°C to 70°C, Storage: -40°C to 90°C
    Humidity
    Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
    Certification
    TBD
    Power Consumption
    TBD
    Reference Design
    PN02.1
    Dimensions (WxHxD)
    57mm x 63mm x 6mm
    M.2 Pin Definitions
    Pin No.
    Name
    Pin No.
    Name
    GND
    VDD3P3_PCIE
    VDD3P3_PCIE
    5
    6
    PCIE_LED0
    7
    GND
    8
    GPIO46_WCI2_UART_TXD_PCIE
    9
    TP19
    10
    GPIO47_WCI2_UART_RXD_PCIE
    11
    12
    13
    14
    15
    VDD_XPA_PCIE
    16
    PCIE_LED1
    17
    VDD_XPA_PCIE
    18
    GND
    19
    VDD_XPA_PCIE
    20
    21
    VDD_XPA_PCIE
    22
    23
    VDD_XPA_PCIE
    33
    GND
    32
    35
    PCIE0_RX0_P
    34
    37
    PCIE0_RX0_N
    36
    39
    GND
    38
    MOD_BT_STS_2
    41
    PCIE0_TX0_P
    40
    MOD_WL_ACT_2
    43
    PCIE0_TX0_N
    42
    PINE_BT_ACT_2
    45
    GND
    44
    MOD_BT_STS
    47
    PCIE0_REFCLK_P
    46
    MOD_WL_ACT
    49
    PCIE0_REFCLK_N
    48
    PINE_BT_ACT
    51
    GND
    50
    53
    PCIE0_CLKREQ_3P3_N
    52
    PCIE0_PERST_3P3
    55
    PCIE0_WAKE_3P3_N
    54
    57
    GND
    56
    59
    PCIE0_RX1_P
    58
    61
    PCIE0_RX1_N
    60
    63
    GND
    62
    65
    PCIE0_TX1_P
    64
    67
    PCIE0_TX1_N
    66
    69
    GND
    68
    71
    70
    73
    72
    VDD3P3_PCIE
    75
    GND
    74
    VDD3P3_PCIE
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult.
(Web:wallystech  com)
EMAIL:sales@wallystech.com
