查看: 1368|回复: 0
wallys//IPQ6018,IPQ4019,IPQ4029,802.11ax,802.11ac
发表于 2022-5-26 10:45:11 | 显示全部楼层 |阅读模式
Description
DR-AP6018-S(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR6018-S Board;1 x  Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
Planar Antenna
■  2 x 5G Antenna
■  5G: 16dbi
DRA25 Antenna
ElectricalProperties :
Frequency Range:2.4~2.5&5.15~5.85GHz
Impedance:50Ω
VSWR:2.0 Max (≤2.0)
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable
Connector:N-type PLUG
Antenna CAP:ABS
OperatingTemp:-40℃~+65℃
Storage Temp:-40℃~+75℃
CableTemp:<+250℃
Enclosure
■  Dimension: 275x140x48mm
■  UV Protected and Durable ABS Radome
■  IP67 Waterproof Level
■  Support Wallys’DR6018-S
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48V(DC Jack)
    V
    Operating Temperature Range
    -40 to +70
    oC
    Storage Temperature Range
    -45 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
    SD Card Slot
    1x SD Card Slot(Option)
    USB /header
    1x USB 3.0 Port(Option)
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V~48V power supply
    LED header
    2.0 pitch pin header
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Nor Flash
    8MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    125mm x 105mm x 20mm
    Radio TX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    5Ghz 802.11ax HE20
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    5Ghz 802.11ax HE400
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    5Ghz 802.11ax HE80
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    Radio TX Specifications(2412MHz-2482MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    2.4Ghz 802.11ax HE20
    MCS0
    23dbm
    26dbm
    ±2dB
    MCS1
    23dBm
    26dBm
    ±2dB
    MCS2
    23dBm
    26dBm
    ±2dB
    MCS3
    23dBm
    26dBm
    ±2dB
    MCS4
    23dBm
    26dBm
    ±2dB
    MCS5
    23dBm
    26dBm
    ±2dB
    MCS6
    23dBm
    26dBm
    ±2dB
    MCS7
    22dBm
    25dBm
    ±2dB
    MCS8
    21dBm
    24dBm
    ±2dB
    MCS9
    21dBm
    24dBm
    ±2dB
    MCS10
    18dBm
    21dBm
    ±2dB
    MCS11
    17dbm
    20dbm
    ±2dB
    2.4Ghz 802.11ax HE40
    MCS0
    23dbm
    26dbm
    ±2dB
    MCS1
    23dBm
    26dBm
    ±2dB
    MCS2
    23dBm
    26dBm
    ±2dB
    MCS3
    23dBm
    26dBm
    ±2dB
    MCS4
    23dBm
    26dBm
    ±2dB
    MCS5
    23dBm
    26dBm
    ±2dB
    MCS6
    23dBm
    26dBm
    ±2dB
    MCS7
    22dBm
    25dBm
    ±2dB
    MCS8
    21dBm
    24dBm
    ±2dB
    MCS9
    21dBm
    24dBm
    ±2dB
    MCS10
    21dBm
    24dBm
    ±2dB
    MCS11
    19dbm
    22dbm
    ±2dB
    GPIO Pin Mapping
    GPIO Pin Mapping
    Pin
    Signal
    Pin
    Signal
    GPIO_0
    AUDIO_MUTE_BUT
    GPIO_1
    QPIC_BUSY_N
    GPIO_2
    MIC_VOL_M
    GPIO_3
    QPIC_WE_N
    GPIO_4
    QPIC_RE_N
    GPIO_5
    QPIC_DAT4
    GPIO_6
    QPIC_DAT5
    GPIO_7
    QPIC_DAT6
    GPIO_8
    QPIC_DAT7
    GPIO_9
    WPS
    GPIO_10
    QPIC_CLE_N
    GPIO_11
    QPIC_NAND_CE_N
    GPIO_12
    QPIC_DAT1
    GPIO_13
    QPIC_DAT2
    GPIO_14
    QPIC_DAT3
    GPIO_15
    QPIC_DAT0
    GPIO_16
    MIC_KPD_PWR_N
    GPIO_17
    QPIC_ALE
    GPIO_18
    KYPD_HOME_N
    GPIO_19
    GND
    GPIO_20
    Boot_Config(PULL_DOWN)
    GPIO_21
    MUTE_ON
    GPIO_22
    ADC_RST
    GPIO_23
    WSA_SWR_CLK
    GPIO_24
    WSA_SWR_DATA
    GPIO_25
    PWM_LED_RST
    GPIO_26
    GPIO_27
    WSA_EN_R
    GPIO_28
    WSA_EN_L
    GPIO_29
    PDM_CLK0
    GPIO_30
    PDM_DATA0
    GPIO_31
    PDM_CLK1
    GPIO_32
    PDM_DATA1
    GPIO_33
    EXT_MCLK2_ADC
    GPIO_34
    MIC_VOL_P
    GPIO_35
    LED_5G
    GPIO_36
    PCIE0_WAKE
    GPIO_37
    LED_2GS
    GPIO_38
    SPI0_CLK
    GPIO_39
    SPI0_CS_NI
    GPIO_40
    SPI0_MISO
    GPIO_41
    SPI0_MOSI
    GPIO_42
    BLSP2_SCL
    GPIO_43
    BLSP2_SDA
    GPIO_44
    BLSP2_UART_RX
    GPIO_45
    BLSP2_UART_TX
    GPIO_46
    BLSP5_SCL
    GPIO_47
    BLSP5_SDA
    GPIO_48
    NC
    GPIO_49
    GPIO_50
    LED_USB0
    GPIO_51
    BT_PRIORITY_PTA11
    GPIO_52
    WLA_ACTI_PTA12
    GPIO_53
    BT_ACT_PTA10
    GPIO_54
    GPIO_55
    NC
    GPIO_56
    NC
    GPIO_57
    NC
    GPIO_58
    NC
    GPIO_59
    PCIE0_CLK_REQ
    GPIO_60
    PCIE0_RSTn
    GPIO_61
    NC
    GPIO_62
    SD_DET
    GPIO_63
    SD_WP
    GPIO_64
    MDC
    GPIO_65
    MDIO
    GPIO_66
    SD_LDO_EN
    GPIO_67
    NC
    GPIO_68
    NC
    GPIO_69
    SPI_CLK_UART_RTSn
    GPIO_70
    SPI_CS_UART_CTSn
    GPIO_71
    SPI_MISO_UART_RX
    GPIO_72
    SPI_MOSI_UART_TX
    GPIO_73
    USB_OTG
    GPIO_74
    NC
    GPIO_75
    Malibu_RESET
    GPIO_76
    NAPA_INT0
    GPIO_77
    NAPA_RESET
    GPIO_78
    QTZ_INT
    GPIO_79
    QTZ_RESET
    Boot Config Switch
    Boot_Config Switch1(S7)
    Boot_Config
    Boot up InterfaceSelect
    S7A
    S7B
    S7C
    SPI NOR. (Default)
    eMMC
    QPIC, Parallel NAND
    USB3.0
    SPI-NOR-GPT
    S7D
    Boot from code ram.(Default)
    Boot from ROM
    Boot_Config Switch2(S9)
    Boot_Config
    No auth.(Default)
    Auth is required
    Product MAP
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
