查看: 2560|回复: 0
[已解答问题] Network_Card/DR900VX/ 802.11ac/QCA9880/Wallys
发表于 2022-6-9 16:47:40 | 显示全部楼层 |阅读模式
QCA9880 802.11ac Dual band
QCA9880 3x3 2.4G/5G FCC/CE/IC
DR900VX
https://www.wallystech.com/Network_Card/DR900VX-Qualcomm-Atheros-QCA9880-3T3R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2-4GHz-5GHz.html
Wallys Communications (Suzhou ) Co., LTD (http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period. We are also a supplier to Facebook, the quality of the product is unquestionable
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales3@wallystech.com
wifi6 router/network card
wifi 6E
WiFi 6
802.11ax/802.11ac
wireless solutions
Dipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna
Wireless Access Point/Point to Point /
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
    Specifications
    Symbol
    Parameter
    Chipset
    QCA9880
    Host Interface
    Mini PCI Express 1.1 Standard
    Antenna Connector
    3 x UF.L
    Frequency Range
    2.4GHz: 2.412GHz to 2.472GHz
    5GHz: 4.920GHz to 5.825GHz
    Operating Voltage
    3.3V DC
    Power Consumption
    5W(Max)
    Modulation Techniques
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
    Environmental Temperature
    Operating: -40°C to 70°C, Storage: -40°C to 90°C
    Environmental Humidity, non-condensing
    Operating: 5% to 95%, Storage: Max. 90%
    ROHS Compliance
    YES
    Dimensions (W×H×D)
    30.0mm × 50.9mm × 3.2mm
    RF Performance Table
    Operating Mode
    Data Rate
    TX Power
    Tolerance
    1 Chain
    3 Chains
    2.4 GHz
    802.11b
    1Mbps
    20dBm
    25dBm
    ±2dB
    2Mbps
    20dBm
    25dBm
    ±2dB
    5.5Mbps
    20dBm
    25dBm
    ±2dB
    11Mbps
    20dBm
    25dBm
    ±2dB
    2.4 GHz
    802.11g
    6Mbps
    21dBm
    26dBm
    ±2dB
    9Mbps
    21dBm
    26dBm
    ±2dB
    12Mbps
    21dBm
    26dBm
    ±2dB
    18Mbps
    21dBm
    26dBm
    ±2dB
    24Mbps
    21dBm
    26dBm
    ±2dB
    36Mbps
    20dBm
    25dBm
    ±2dB
    48Mbps
    19dBm
    24dBm
    ±2dB
    54Mbps
    19dBm
    24dBm
    ±2dB
    2.4 GHz
    802.11n HT20
    MCS0
    21dBm
    26dBm
    ±2dB
    MCS1
    21dBm
    26dBm
    ±2dB
    MCS2
    21dBm
    26dBm
    ±2dB
    MCS3
    20dBm
    25dBm
    ±2dB
    MCS4
    20dBm
    25dBm
    ±2dB
    MCS5
    20dBm
    25dBm
    ±2dB
    MCS6
    19dBm
    24dBm
    ±2dB
    MCS7
    18dBm
    23dBm
    ±2dB
    2.4 GHz
    802.11n HT40
    MCS0
    21dBm
    26dBm
    ±2dB
    MCS1
    21dBm
    26dBm
    ±2dB
    MCS2
    21dBm
    26dBm
    ±2dB
    MCS3
    20dBm
    25dBm
    ±2dB
    MCS4
    20dBm
    25dBm
    ±2dB
    MCS5
    20dBm
    25dBm
    ±2dB
    MCS6
    19dBm
    24dBm
    ±2dB
    MCS7
    18dBm
    23dBm
    ±2dB
我知道答案 回答被采纳将会获得5 联盟币 已有0人回答
