& Y8 b+ `+ S0 k3 L7 X* w- h
Support WiFi 6E Card,802.11ax,QCN9074 5 ?. V# c2 l- ]+ G
IPQ8072 4x4 2.4G & 5G 802.11ax 6 i$ a: B& O" z7 N A
s" y9 m3 B9 O
DR8072 V01
( v" T8 t" a; x5 S1 A0 nWallys Communications (Suzhou ) Co., LTD (http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period. We are also a supplier to Facebook, the quality of the product is unquestionable1 o& J, r+ N4 [0 h6 P5 t) a' P- j" H: b
/ }+ t" k. R5 `- Y4 K! f% c7 SIPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/
" G# a( F7 b) ?" CBY:Wallys Communications (Suzhou ) Co., LTD0 r* P6 ^ g* Q9 B
EMAIL:​sales3@wallystech.com
+ f {( k* ?; U0 }9 s" W1 l# x( A7 i7 o- s9 F; P' v5 l
wifi6 router/network card
' ~3 V0 m5 q0 ?4 kwifi 6E
. r* D0 F8 a. _" RWiFi 6' j$ H& W' a7 r s" ]% F4 N
802.11ax/802.11ac9 H8 n- S: g/ A3 s5 c9 g8 p
wireless solutions
3 v: C3 F: I Q# |7 f! zDipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna
8 T6 q+ c5 g. I% \! J lWireless Access Point/Point to Point /+ y% O1 ^3 T4 k
$ s9 o! _4 `2 R4 H! h) P
6 J1 N, I6 P5 T" O% xhttps://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html# [' E$ A- Q7 V) f. v. k
p+ B. {, U# x) g/ ]0 F, ?
Features■ Qualcomm Atheros IPQ8072A AR Quad Core CPU ■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate ■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional) ■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL ■ Supports Dynamic Frequency Selection (DFS) ■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional) ■ M.2 connector can support QCN9074 production $ @6 Q# T% P0 W8 p
t0 c* G7 C6 s9 Z( B4 [- N. K7 ] W5 \
Parameter | Rating | Unit | Operating Temperature Range | -20 to +70 | oC | Storage Temperature Range | -40 to +90 | oC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % | 8 Q! e' K3 h) M# ?+ }
| Hardware Specifications
) C/ ?% @1 l7 |5 Y: D! M | + B8 c# D; I; |5 O+ Y- c5 k
' p2 T# k3 @1 H4 n. k
Symbol5 h3 G5 k& @+ ?! q; f0 W
| Parameter
- E3 }: t% @( \' B | CPU
4 S) C3 O. D0 k, I5 @* Z( @ | Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
6 v* e3 n% X* f/ k7 T( ^ | CPU Frequency: p# F2 H8 k: }, P' ~1 s
| Derived from Qualcomm Atheros AP.HK09
, ^( w, N, B/ k/ h- H | System Memory
7 _* l6 s" c3 `0 }' ^3 o | 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
7 [! o8 X1 x( U& L5 ^0 a& \ | Frequency Range& M9 |: i. D: X
| 2.412~2.472GHz,
, V: V' p/ c6 E5.150~5.825GHz! [; r4 \! _0 w( C8 P, I1 }
| M.2 Slot3 i- {: d" [/ R( c( ?( p- K9 A- j
| 1x M.2 Slot with PCIe 3.0) l/ j3 _- }' d; [4 X5 L: k) h
| Modulation Techniques
0 Q; `. S9 U$ N( T | OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, _( r2 o' N* f" K% j, G+ a
| Environmental Temperature
, Y, d9 X$ Q. h2 w2 t: e | Operating: -20oC to 70oC, / F1 [6 g, g! K6 N' \7 D
Storage: -40oC to 90oC
: o. n- I7 D' p4 ?7 A6 s) H6 C | Flash
; p( A/ j8 w5 X! \ | NOR Flash: 8 MB ( ^8 ?2 T9 p- g- R$ a* ?
NAND Flash: 256MB(1GB optional)' o% I7 m3 k! p0 w
| Wireless
0 O, b, s9 }! ?* Z | On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain % E6 o6 ~! F5 R3 ], N
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
& J: X; b3 P/ P) [3 V8x U.FL Connectors
+ \- D% c8 x- Z5 { | Reset Buttons
( l+ H# h N+ V$ K: ] | 1x S/W Reset Button( a g. N& J8 H4 S" v# O+ o8 O* g
| DC Jack Input
6 o0 F3 ?. z/ C# H) e | 1x DC Jack Connector: 12V+ K2 f2 o F$ t, y$ ]
& x: x h/ g) _+ RInterface
; p( `4 x7 o3 j- i6 J | 4x 1Gbps Ethernet Port,
/ S0 `5 N- G; b% Y" n0 t1x 10Gbps Ethernet Port
4 \8 F# ~& S5 C# ~- E( O& ]1x 10Gbps SFP7 E" S) V) T8 U0 }
2x USB 3.0 Port 9 f8 P B, j8 W. g0 A
1x JTAG 20 Pin Connector
8 [( G7 p( }& J* Z1x Serial Port 4 Pin Connector! d. W3 t# C! H3 }
| LED( A- {# K2 U+ P% E- ~$ ]" z5 K2 h
| 2x RGB LED Indicators) ]* b( o) H* V! Y2 U9 y
| Power Consumption% P+ C# j8 u1 j
| TBD2 B O: i' r# N6 }' {8 Z; R$ r0 g7 ~1 E
* ?! b% o" b+ ?: E5 A4 c; n; J3 R# s3 u I5 @
! t! T: a2 l$ L2 P* B
# v; y$ A: [! c4 g7 n& h; L" r6 J
