软件是ISE14.7,芯片是XC3S50
2 i. P6 f. s/ s& oChipScope生成cdc文件的时候都没有问题. q0 t9 ~! z. ]
- x# X1 j' A$ D' j( k1 e
但是在加载bit文件的时候出现如下错误:
3 G& [! U+ U- N1 I) Y& A- v; Q3 u8 M. y' {/ A4 y' j- c- r4 L
COMMAND: open_cable" q( ?6 v. N' Z( q; Q5 [7 ?1 X
INFO: Started ChipScope host (localhost:50001)
. Q/ y6 F v$ d- Y) dINFO: Successfully opened connection to server: localhost:50001 (localhost/127.0.0.1)
6 B& j% X9 i+ u2 J( B! MINFO: Trying to open Xilinx Platform USB Cable on port USB2
& z0 f2 q, r8 `; t. F' EINFO: Successfully opened Xilinx Platform USB Cable4 p* o" p3 M% q- J# a* [0 l
INFO: Cable: Platform Cable USB II, Port: USB21, Speed: 3 MHz
5 i9 v1 q! ?) L9 y2 f5 zINFO: Found 0 Core Units in the JTAG device Chain.& Y. L1 @6 f9 o: G
INFO: If cores were expected to be found, see Answer Record 19337.% j4 z$ C8 ^4 F8 {$ `
COMMAND: configure 1 "D:\FPGA\Timing_chipscope\main.bit" 0 import_inserter_cdc "D:\FPGA\Timing_chipscope\" "chipscopewave.cdc" doAuto. Y& f- T/ R8 }0 H
ERROR: Configuration failed.
2 [& C- L8 D8 u! `/ ~INFO: DEV:1 MyDevice1 (XC3S50) is not configured) Y' [7 i2 g9 P0 j! J/ L ?
COMMAND: import_inserter_cdc "D:\FPGA\Timing_chipscope\" "chipscopewave.cdc" 1 DoAuto
+ d" J" k: U9 w% K- Y
% L1 s* s* { O$ m4 vps:下载线是正常的,试过了没问题
. c1 q0 R# E( l ?! J. I请问是什么原因?9 A/ ]2 |1 L* k1 s
该如何解决?" ^0 F: z- Z5 M& _/ O
谢谢!
! X h9 t: Z4 C; x, G6 N |
