查看: 2655|回复: 0
Wallys/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-
发表于 2022-6-21 16:12:31 | 显示全部楼层 |阅读模式
WiFi6 MiniPCIe Module 2T2R
2×2.4GHz 2x5GHz
DR 7915
https://www.wallystech.com/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module.html
Wallys Communications (Suzhou ) Co., LTD (http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period. We are also a supplier to Facebook, the quality of the product is unquestionable
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/
BY:Wallys Communications (Suzhou ) Co., LTD
wifi6 router/network card
wifi 6E
WiFi 6
802.11ax/802.11ac
wireless solutions
Dipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna
Wireless Access Point/Point to Point /
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 35dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
CardsareindividuallycalibratedforQualityAssurance
    Product Description
    DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
    specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
    Specifications
    Symbol
    Parameter
    Chipset
    MT7915+MT7975
    Host Interface
    Mini PCI Express 2.1
    Antenna Connector
    2 x UF.L
    Frequency Range
    2.4GHz: 2.412GHz to 2.472GHz
    5GHz: 5.180GHz to 5.825GHz
    Operating Voltage
    3.3V DC
    Power Consumption
    TBD
    Modulation Techniques
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
    Environmental Temperature
    Operating: -40°C to 70°C, Storage: -40°C to 90°C
    Environmental Humidity, non-condensing
    Operating: 5% to 95%, Storage: Max. 90%
    ROHS Compliance
    YES
    Dimensions (W×H×D)
    51mm × 30mm × 5.8mm
    RF Performance Table
    Operating Mode
    Data Rate
    TX Power
    Tolerance
    1 Chain
    2 Chains
    2.4 GHz
    802.11b
    11Mbps
    20dBm
    23dBm
    ±2dB
    2.4 GHz
    802.11g
    54Mbps
    17dBm
    20dBm
    ±2dB
    2.4 GHz
    802.11n HT20
    MCS7
    17dBm
    20dBm
    ±2dB
    2.4 GHz
    802.11n HT40
    MCS7
    14dBm
    17dBm
    ±2dB
    Operating Mode
    Data Rate
    RX Sensitivity
    Tolerance
    2.4 GHz
    802.11b
    11Mbps
    -96dBm
    ±2dB
    2.4 GHz
    802.11g
    54Mbps
    -93dBm
    ±2dB
    2.4 GHz
    802.11n HT20
    MCS7
    -89dBm
    ±2dB
    2.4 GHz
    802.11n HT40
    MCS7
    -86dBm
    ±2dB
    Operating Mode
    Data Rate
    TXPower
    Tolerance
    1 Chain
    2 Chain
       5 GHz
      802.11a
    54Mbps
    17dBm
    20dBm
    ±2dB
       5 GHz
      802.11n/ac HT20
    MCS8
    15dBm
    20dBm
    ±2dB
      5 GHz
      802.11n/ac HT40
    MCS9
    14dBm
    17dBm
    ±2dB
    5 GHz
      802.11n/ac HT80
    MCS9
    11.5dBm
    14.5dBm
    ±2dB
      5 GHz
      802.11n/ac HT20
    MCS9
    17dBm
    20dBm
    ±2dB
      5 GHz
      802.11n/ac HT40
    MCS9
    14dBm
    17dBm
    ±2dB
      5 GHz
      802.11n/ac HT80
    MCS11
    11dBm
    14dBm
    ±2dB
