WiFi 6E (802.11ax) 4×4 MU-MIMO 6GHz QCN9074 Single Band Wireless ModuleQCN9074 802.11ax 4x4 MU-MIMO 6GHz wifi6E
QCN9074 11ax 4x4 6G M.2
DR9074-6E(PN02.7)
Features - Qualcomm Atheros QCN9074
- 6GHz, max 23dBm per chain, up to 4949Mbps
- Single Band 6GHz 4×4 WiFi 6E (802.11ax)
- 4 spatial streams (4SS)
- M.2 E Key Interface
- PCI Express 3.0 Interface
Applications - Security Surveillance
- Commercial radio coverage
- Hotel Wireless application
- Country coverage
- Forest fire protection engineering
- Some special scene application
Product Description DR9074-6E (PN02.7) based on IPQ9074 Chipset is an enterprise wireless module integrated
with 4×4 MU-MIMO 6GHz Single Band Wireless Module designed specifically to provide users
with mobile access to high-bandwidth video streaming, voice, and data transmission for office
and challenging RF environment in factories, warehouses establishment Absolute Maximum Rating Parameter | Rating | Unit | Operating Temperature Range | -20 to 70 | oC | Storage Temperature Range | -40 to 90 | oC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Hardware Specifications Symbol | Parameter | Chipset | Qualcomm Atheros QCN9074 | WLAN Host Interface | PCI Express 3.0 Interface | System Memory | 2Mbit serial I2C bus EEPROM | Standard Operating Voltage | 5V | Operating Systems | OpenWRT | Host Interface | M.2 E Key | Antenna Cable / Port | 4xU.FL Connectors,4T4R | Frequency Range | 5.925GHz-7.125GHz | Data Rates for WALN | 6GHz, max 23dBm per chain, up to 4949Mbps | Channel Spectrum Widths
for WLAN | Support 20/40/80/160MHz at 6GHz | Modulation Techniques | OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM | Temperature Range | Operating: -20°C to 70°C, Storage: -40°C to 90°C | Humidity | Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing) | Certification | TBD | Power Consumption | TBD | Reference Design | PN02.7 | Dimensions (WxHxD) | 57mm x 60mm x 3.2mm |
#QCN9074-6E #WiFi6E #6GHz #PN02.7
