Adapter card(one pcie1x to 4 x Mini PCIE)Linux,WiFi-modules,4-miniPCIE-slot * g1 E& ]- C& i; w
Adapter Card 4 x Mini PCIe Card 4 x M.2 Card
6 r* g4 U' W, B# Z- I
* k* K* D( V2 i* d0 KDR2G416 V4 X8 {6 q q
https://www.wallystech.com/Routerboard/DR2G41-Linux-PCIe-adapter-for-miniPCIe-and-M.2-WiFi-modules-4-miniPCIE-slot-to-PCIe-adapter.html: t) ?6 Y# j' e; o& ]
" j) t" u$ w7 ^- n0 T; Z
6 d5 u: f, Z# K
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IPQ9074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344
$ [- N# o& x+ z s$ i' L# ]BY:Wallys Communications (Suzhou ) Co., LTD
Z) i# j( e" |; s" WEMAIL:​sales3@wallystech.com; Q3 T, R3 @% B4 p. E
0 r6 \' k2 y, C$ r1 ~
5 y) k- ]0 R- x' V$ F/ s' rWallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is a professional supplier specializing in product design, manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China,We sincerely hope to establish business relations with your esteemed corporation.
1 u3 `- G* e3 Q2 y. J
" N7 q1 {6 N$ v: jFeatures - Support 4pcses Mini PCIE card or 4 pcses M.2 card
- Support Many kinds of wireless card
- Support RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
- e/ x* L' K; E
Applications - Security Surveillance
- Commercial radio coverage
- Hotel Wireless application
- Country coverage
- Forest fire protection engineering
- Some special scene application
3 T8 b# w% u+ C
Product Description 524wifi 2G41 is an adapter card with four MiniPCIe and four M.2 slots. It can be used in a PC with a PCIe slot. Use this new adapter to expand your connectivity and upgrade your device to use the latest miniPCIe and m.2 interface cards. Each comes with both low and regular profile brackets. Brackets include holes for mounting SMA connectors, or for using as cable exit holes. Specifications Parameter | Rating | Unit | Input voltage | 12 | V | Output Voltage | 3.3 | V | Operating Temperature | -40 to +70 | oC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % | ROHS Compliance | YES |
3 A6 v" K7 q7 g) M4 C |
Switch control instruction Switch | up/down | Operation | Switch 1 | up | M.2-1 | down | MiniPCIE-1 | Switch 2 | up | M.2-2 | down | MiniPCIE-2 | Switch 3 | up | M.2-3 | down | MiniPCIE-3 | Switch 4 | N/A | M.2-4 and MiniPCIE-4 can work simultaneously,not controlled by the switch 4 |
Outline Parameter | Rating | Unit | Length | 180 | Mm | Width | 66 | Mm | ( z" u9 L, w: C7 s
8 g+ R* e& @1 K' c1 D( H: H- v$ f7 F
% |6 }& r/ X% u; ^5 {
- x+ I% t/ E: A0 I2 V- l" z
% [) t; s7 j! L7 W% H- V! g : q; k1 Q) |7 {; C) ]
8 \. c2 E+ j4 P4 E1 ~( \
