查看: 2240|回复: 5
ERROR -- Can't find library
发表于 2022-7-15 15:08:53 | 显示全部楼层 |阅读模式
请大侠解答,我在做Pspise仿真时出现ERROR -- Can't find library
.lib "nom.lib" ,是不是我改了三极管的参数的原因,要怎么改正,谢谢!
发表于 2022-7-15 15:09:46 | 显示全部楼层
我遇到同样的问题了,前辈,有方法了吗?
发表于 2022-7-15 15:10:06 | 显示全部楼层
你在仿真工具栏中点击 Edit Sim..Profile ,选择那个Configuration file ,下面那个Library 中看看那个 nom.lib文件的位置是否正确,如果不正确从新找到那个文件,位置不用我说了吧,添加为Global、、、、、如果还提示某些库文件找不到的话,那就在 tools/pspice/library中,,用记事本打开那个nom.lib,看看里面的意思和格式,,看你用的库文件的有没有包含进去
发表于 2022-7-15 15:10:16 | 显示全部楼层
不懂,怎么解决?
发表于 2022-7-15 15:10:41 | 显示全部楼层
**** RESUMING freq.cir ****
.END
ERROR(ORPSIM-15108): Subcircuit uPC4560 used by X_U3A is undefined
ERROR(ORPSIM-15108): Subcircuit uPC4560 used by X_U3B is undefined
ERROR(ORPSIM-15108): Subcircuit uPC4560 used by X_U4A is undefined
我的软件安装完使用也出现了问题,请问下怎么解决?
我的元件是在OPAMP.LIB里面的,我有进入到MIND.LIB里面但是我不确定内容是否正确,以下是内容:
* Sample standard device library
*  Copyright Cadence Design Systems, Inc. 2000 All Rights Reserved.
* This is a reduced version of PSpice A/D's standard parts libraries. Some
* components from several types of component libraries have been included
* here.  You are welcome to make as many copies of it as you find convenient.
* $Revision:   1.6  $
* $Author:   HIRASUNA  $
* $Date:   11 May 2000 09:36:36  $
* The model library included with the production version of PSpice A/D
* includes over 14,000 analog devices, and over 1,800 digital devices.
* It takes time for PSpice to scan a library file.  To speed this up, PSpice
* creates an index file, called <filename>.IND. The index file is re-created
* whenever PSpice senses that the library file has changed.
.lib "breakout.lib"             ; generic devices for schematic capture
* "regular" device libraries
.lib "eval.lib"                 ; reduced version of PSpice A/D's standard
                                ; parts libraries. Some components from
                                ; each of several types of component
                                ; libraries have been included here.
.lib "evalp.lib"                ; sample version of PSpice parameterized
                                ; parts libraries.
.lib "templates.lib"            ; dummy template library
.lib "evalAA.lib"  ; Adv Analysis Parts.
* end of library file
发表于 2022-7-15 15:10:52 | 显示全部楼层
求楼主给我发一下这个软件吧1606095806@qq.com,,要是可以的话真的是太感谢了
