香蕉派 BPI-P2 Zero 四核开源物联网开发板,采用全志H2+芯片设计,也可以直接用在H3,H5芯片方案。Banana Pi BPI-P2 Zero 是一种小巧的物联网开发板,板子尺寸只有65毫米52.5毫米。它使用四核 H2+处理器(也可以选择全志H3和H5),有512 MB内存。8 G eMMC,100兆网口,支持PoE功能,wifi无线支持,它支持linux和android操作系统。
关键特性[]
CPU: Allwinner H2+, Quad-core Cortex-A7.
512MB DDR 3 SDRAM.
WiFi (AP6212) & Bluetooth onboard.
Mini HDMI.
40 PIN GPIO,It includes UART, SPI, I2C, IO etc
100M LAN
IEEE 802.3af PoE standard PoE module support
8G eMMC flash onboard.
硬件接口:
硬件规格
HardWare Specification of Banana pi BPI-P2 Zero VS BPI-M2 zero VS Raspberry Pi Zero W
型号 Banana Pi BPI-P2 Zero Banana Pi BPI-M2 Zero Raspberry Pi Zero W
CPU主控 H2+ Quad-core Cortex-A7 H265/HEVC 1080P H2+ Quad-core Cortex-A7 H265/HEVC 1080P Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
GPU Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 VideoCore IV
Memory \(SDRAM\) 512M DDR3(shared with GPU) 512M DDR3(shared with GPU) 512 MB DDR2
Onboard Storage TF card \(Max. 64GB\) TF card \(Max. 64GB\) TF card \(Max. 64GB\)
有线网络 100M LAN NOPE (but can extension with PIN define) NOPE
PoE 网线供电 PoE function support NOPE NOPE
Onboard flash 8G eMMC NOPE NOPE
WIFI无线 SDIO AP6212(option AP6181、AP6335) SDIO AP6212(option AP6181、AP6335) 802.11n wireless, Bluetooth 4.1
Video decoding 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder
Video input A CSI input connector Camera A CSI input connector Camera CSI camera connector
Video Outputs mini HDMI 1.4,1080P@30fps, DHCP mini HDMI 1.4,1080P@30fps, DHCP Mini HDMI and USB On-The-Go ports
Audio Output Mini HDMI Mini HDMI Mini HDMI
供电 Micro USB with 5V/2A or PoE power Micro USB with 5V/2A 5V/2A
USB 2.0 Ports one USB 2.0 OTG one USB 2.0 OTG one USB 2.0 OTG
按键 Power Button, Reset Button Power Button, Reset Button Composite video and reset headers
Low-level peripherals 40 Pins Header,compatible with Raspberry Pi 3 40 Pins Header,compatible with Raspberry Pi 3 40 PIN
uart GPIO\(1x3\) pin UART, ground UART, ground UART
LED灯 Power led & Status led Power led & Status led Power Status LED
IR红外控制 N/A N/A N/A
支持系统 android linux android linx Linux
产品尺寸 65mm X 52.5mm 65mm × 30mm 65mm x 30mm
重量 30g 15g 9g
支持POE网络供电:
在线wiki文档:
http://wiki.banana-pi.org/%E9%A6%99%E8%95%89%E6%B4%BE_BPI-P2_Zero |
