IPQ5018, 802.11ax,wifi 6e,QCN9074,
2X2 2.4G support 2x WiFi 6E Card support BT5.1
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IQCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW
Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is a professional supplier specializing in product design, manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China,We sincerely hope to establish business relations with your esteemed corporation.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales3@wallystech.com
DR5018
https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.html
512MB DDRL3L System Memory 4MB NOR Flash, 128MB NAND Flash 2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate Support BT5.1 M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ; M.2 Card Slot for QCN9074 WIFI 6E Card
Parameter
| Rating | Unit | Supply Voltage
| 12 | V | Operating Temperature Range
| -40 to +70 | oC | Storage Temperature Range
| -45 to +105 | oC | Operating Humidity Range
| 5 to +95 (non-condensing) | % |
Symbol
| Parameter | CPU
| Qualcomm-Atheros IPQ5018
| CPU Frequency
| Dual-core ARM 64 bit A53 @1.0 GHz processor
| System Memory
| 512MB DDR3L 16-bit interface with 32-bit memory bus design
| Ethernet Port
| 4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
| NGFF Slot
| M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
| EMMC
| 4G/8G(optional)
| USB /header
| 1x USB 3.0 Port
| POE
| NA
| DC Jack
| 12V power supply
| LED header
| LED for power ,Wifi strength
| Serial Port
| support
| Wireless
| On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
| Bluetooth | BT5.1
| Nor Flash
| 8MB
| Nand Flash
| 128 MB
| DDR
| 512MB
| Dimension
| 170mm x 120mm x 15mm
| Radio TX Specifications(2412MHz-2482MHz) |
Operating Mode | Data Rate | Power | Tolerance | 1 Chain | 2 Chains | 2.4Ghz 802.11ax HE20 | MCS0 | 23dbm | 26dbm | ±2dB | MCS1 | 23dBm | 26dBm | ±2dB | MCS2 | 23dBm | 26dBm | ±2dB | MCS3 | 23dBm | 26dBm | ±2dB | MCS4 | 23dBm | 26dBm | ±2dB | MCS5 | 23dBm | 26dBm | ±2dB | MCS6 | 23dBm | 26dBm | ±2dB | MCS7 | 22dBm | 25dBm | ±2dB | MCS8 | 21dBm | 24dBm | ±2dB | MCS9 | 21dBm | 24dBm | ±2dB | MCS10 | 18dBm | 21dBm | ±2dB | MCS11 | 17dbm | 20dbm | ±2dB | 2.4Ghz 802.11ax HE40 | MCS0 | 23dbm | 26dbm | ±2dB | MCS1 | 23dBm | 26dBm | ±2dB | MCS2 | 23dBm | 26dBm | ±2dB | MCS3 | 23dBm | 26dBm | ±2dB | MCS4 | 23dBm | 26dBm | ±2dB | MCS5 | 23dBm | 26dBm | ±2dB | MCS6 | 23dBm | 26dBm | ±2dB | MCS7 | 22dBm | 25dBm | ±2dB | MCS8 | 21dBm | 24dBm | ±2dB | MCS9 | 21dBm | 24dBm | ±2dB | MCS10 | 21dBm | 24dBm | ±2dB | MCS11 | 19dbm | 22dbm | ±2dB |
