查看: 1694|回复: 0
wallys wifi6 router//IPQ6000 802.11ax 2x2 2.4G 5G 1.7Gbps support openwrt
发表于 2022-8-23 11:10:14 | 显示全部楼层 |阅读模式
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IQCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW
https://www.wallystech.com/Routerboard/DR6000-wifi6-Qualcomm-IPQ6000-2T2R-2-GE-port-MU-MIMO-OFDMA-802.11AX-support-OpenWRT.html
Qualcomm-Atheros IPQ6000
Quad-core ARM 64 bit A53s 1.2GHz processor
2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
2 on board radios (Dual Band Concurrent Radio)
Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    12
    V
    Operating Temperature Range
    -20 to +70
    oC
    Storage Temperature Range
    -45 to +90
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.2GHz processor
    System Memory
    DDR3L 512MB 16-bit interface
    Nand Flash
    128MB
    NOR Flash
    16MB
    Ethernet Port
    2x 1Gbps Ethernet Ports
    DC Jack Input
    1x DC Jack Connector: 12V
    Power Consumption(Board Only)
    1TD
    On Board Radio
    2 radios (Dual band concurrent radio)
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
    Frequency Range
    2.412~2.472GHz, 5.150~5.825GHz
    2.4GHz Data Rate
    5GHz Data Rate
    Modulation Techniques
    OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
    LED
    4x LED Indicators
    USB /Header
    1x MicroUSB 2.0 Port
    Serial Port
    1x Serial Interface 12 Pin Connectors
    Certification
    TBD
    Humidity
    Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
    Temperature Range
    Operating: TBD Storage: -40oC to 90oC
    Dimension (Diameter x Height)
    100mm x 23.5mm (Without Heatsink)
    EMAIL:sales@wallystech.com
    WEB:
