查看: 3096|回复: 4
AD安装遇到的某问题解决方法
发表于 2022-9-5 07:48:14 | 显示全部楼层 |阅读模式
由于某点问题今天卸载了AD想重装一下但是按照  电子二课堂大神的教程一步步安装却遇到了一个问题,选择安装路径之后会出现一个exception report窗口, L& I9 G4 g( K- B/ j  c
front选项卡显示:% k6 ~( n0 h( i6 K% c& m
Altium designer has encountered the following exception :
" |  z: P$ f1 O& u; y- l/ m# W" J" `9 G" B0 c4 {! }5 m6 m( ]  {/ i
Invalid operation in GDI+ (Code: 1)
3 C, E- a7 A7 |7 W: p5 X# `/ I) @& b( C$ Y6 C0 n
Please copy the details to the clip board and include them with your error report
8 Q" H! o- s& t8 {: x
0 U8 x9 s, y3 Y/ `/ c9 W  j) G$ Fdetails选项卡显示:  J6 V7 f" R- S) ^  J
Invalid operation in GDI+ (Code: 1)  x- k3 s/ C3 x
" H8 L, W2 Z& W! t: `# o; I7 S; r
[008B2678]{AltiumInstaller-安装文件.exe} Unknown function at madTraceProcess0 `7 r" [8 f7 A9 y0 V9 j, M2 m
[008B253D]{AltiumInstaller-安装文件.exe} Unknown function at madTraceProcess5 w3 b8 o1 z# `2 M; l3 g+ L
[008B259E]{AltiumInstaller-安装文件.exe} Unknown function at madTraceProcess
1 P+ X; b8 K" L7 j' H[008B6D29]{AltiumInstaller-安装文件.exe} Unknown function at madTraceProcess7 t8 ?/ G! ]* a) W; C
[008AFA37]{AltiumInstaller-安装文件.exe} Unknown function at madTraceProcess7 T5 J8 ~5 O, P9 J) ?; y" U7 D
[008DE6DB]{AltiumInstaller-安装文件.exe} Unknown function at madTraceProcess2 k1 D" m9 U0 E
(000059FE){AltiumInstaller-安装文件.exe} [004069FE]+ M+ J$ J$ v5 |7 u: ?& V1 b
(00005A67){AltiumInstaller-安装文件.exe} [00406A67]
8 `% H1 J9 Z$ h! e( E  B. ]) }[7C816034]{kernel32.dll} Unknown function at RegisterWaitForInputIdle% l& Y0 H* a) J! ?1 S
烦恼了半个小时一直找度娘谷歌都没找到准确的解决方法,后来在论坛上看到讨论到7za.EXE文件,然后自己安装前先打开了一下,之后再进安装则上述问题消失。
发表于 2022-9-5 07:49:10 | 显示全部楼层
你解决了吗,告诉我一下呗  o  x; n% V. z1 C  _
) c0 u+ W) V4 A
发表于 2022-9-5 07:49:42 | 显示全部楼层
发表于 2022-9-5 07:50:36 | 显示全部楼层
Access violation at address 18D3600E in module 'IntegratedLibrary.DLL'. Read of address 00000008 at 18D3600E.% q! t; D0 L8 y  V' j0 J
& N2 Q- n% Z- S0 O6 u5 ~
Failed to load IntegratedLibrary.; z4 Q' f9 G% L0 i1 W
# c8 A4 F  g( M0 b
Failed to initialize application. Application will terminate!
发表于 2022-9-5 07:51:04 | 显示全部楼层
请问你的问题解决了吗,7za.exe是怎么用的?我安装时也弹出了这个exception report,但是我关掉之后继续安装了,提示安装成功
