查看: 991|回复: 0
Wallys//QCN9074/MT7915 Wireless WiFi intelligent agricultural irrigation,
发表于 2022-9-8 11:02:18 | 显示全部楼层 |阅读模式
Wallys//Wireless WiFi intelligent agricultural irrigation, QCN9074/QCN9024/MT7915+MT7915 technology
The remote monitoring water-saving irrigation system based on WIFI module and the intelligent irrigation water-saving system for agriculture can remotely monitor the temperature and humidity of the field environment, analyze the data transmitted through the cloud, and automatically control the internal environmental parameters, fertilization, irrigation and other equipment.
At the same time, the monitoring information can be dynamically pushed to the manager through the mobile phone, serial port, microcomputer and other user terminals, and the amount of irrigation water can be controlled by analyzing and collecting the information.
Through the diversification of terminals, it provides greater convenience for the information technology of the agricultural production site environment. Intelligent remote monitoring mainly relies on information perception technology, network communication technology, automatic control technology and other advanced technologies.
As a terminal application platform, it can control the waste of irrigation water, greatly reduce the labor cost, realize unattended, adjust the environment correctly, and achieve high efficiency and water saving.
The system includes hardware equipment, microcontroller module, controller module, wireless WiFi communication module, Internet of things cloud server, etc., it is based on the temperature, humidity information of agricultural products, automatically complete real-time irrigation.
Wallys WiFi solution, wireless WiFi technology application. Dr9074–6e and DR7915 are highly integrated, cost-effective, low-power and safe-focused WiFi SOCs with powerful functions, rich IO interfaces and diverse HMI applications.
Respectively based on Qualcomm, MTK algorithm security startup; Flash encryption; Protect private keys and device secrets from software access; Crypto accelerator improves cloud connection performance; Effectively resists physical fault injection attacks.
The sensor uses the wireless sensor network as the hardware equipment of agricultural information perception, and provides the results to the producer, which is mainly used to collect various information of agricultural resources, such as temperature, humidity and other parameters in the process of planting.
As the main control chip to transmit the collected data to the microprocessor module. The router hotspot can be connected through the wifi wireless module of the remote wifi module to realize the communication between the data and the main chip.
Dr9074–6e and DR7915 integrate a wealth of peripheral devices with programmable GPIO, which can be flexibly configured for USB OTG, LCD interface, camera interface, SPI, I2S, UART, ADC, DAC and other common functions.
With an LCD interface and configurable capacitive touch GPIO, the DR9074–6E and DR7915 provide a good solution for touch screen and touch pad based devices.
Data through the router transit, transfer to the remote cloud server, using the platform for data processing and storage, in this way, agricultural administrator can through the network to store data, analysis and decision, instruction to relay switch as the controlled terminal in intelligent irrigation system, the LED lighting for data feedback and control.
Irrigation module is an important part of this design, the so-called intelligent irrigation, first to have the ability of automatic irrigation, through data analysis, when to turn on the pump, when to turn on the pump, when to turn off the pump, stop irrigation.
As a kind of submersible pump, the horizontal submersible pump has the advantages of small size and convenient carrying, which can be widely used in agricultural production. DR9074 and DR7915 operate from -40 °C to 125 °C and are suitable for various industrial, consumer and lighting applications.
On the basis of WiFi technology, a set of intelligent irrigation system is designed, which combines these different components. Each component has different functions and is indispensable. All the components are connected together to form an overall control system
After the appropriate WiFi network is found, the sensor will transmit the collected data to the host computer and the cloud platform. If it cannot reach the standard environmental parameter value, it will process the relevant data, judge whether it is automatic mode, and then feed back to the controlled device and react.
The intelligent irrigation water-saving system management software can directly issue instructions to control the whole system. The software interface displays real-time changes of temperature and humidity signals and the execution buttons of each irrigation valve, which serves as the remote management of each humidity sensor by the irrigation department.
The upper computer software interface of intelligent irrigation and water saving system mainly includes serial port transmission, receiving information, sending information and data storage module. The upper computer sends out control instructions to the system to ensure the normal work of each module.
Thresholds are set to adapt to different environments. The status of the control part of the remote device can be reflected in real time by the button. When the oil pump is turned on, the red indicator on the button is on, and when the red light is off, it is off. In automatic mode, the green light of the button will be turned on, and when the green light is off, it will be in manual mode.
Intelligent agriculture real-time monitoring system based on WiFi technology and Internet of Things sensing. Upload the data detected by various sensors to the cloud platform and upload the data in real time, so that the user can view the parameter data at any time, monitor the agricultural production environment and realize the automation of agricultural irrigation.
The SYSTEM SOLVES THE PROBLEMS OF large WASTE and poor stability of traditional irrigation water resources, fully conforms to the design principle of practicality, openness and convenience, and greatly optimizes the allocation of water resources.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We’re a supplier to Facebook.
Skype/EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
For more related wifi modules, please see the following products
DR600VX
DR900VX
