查看: 1543|回复: 0
The history of wireless communication industry//wallys ipq4019 ipq4029 ipq8072
发表于 2022-9-9 15:51:40 | 显示全部楼层 |阅读模式
IPQ4019 ipq4029 ,802.11AC 2x2 2.4G&5G//IPQ8072 4x4 2.4G & 5G
Since the use of smoke signals, flags and flashing mirrors in the pre – historic period, Wireless communication has been a part of human life and it is continuously evolving. Modern Wireless Communication i.e., using electrical signals and radio waves for communication has been around us for more than 100 years.
In the year 1897, Guglielmo Marconi successfully demonstrated the Wireless Telegraphy by sending EM Waves for a short distance of 100 meters. This demonstration paved way for Radio Communication and the term Radio is derived from Radiant Energy.
By early 1900's, Trans – Atlantic radio transmission had been established, where Marconi successfully transmitted messages in the form of Morse code. Since then, the technology related to wireless communication and wireless system has advanced rapidly and thus enabling transmissions over longer distances at low cost with cheaper devices.
Throughout the development of wireless communication, there are many wireless systems and methods that flourished and many got disappeared. The best example for this is Telephone Communication and Television Transmission. Initially, all telephone related communication was carried out (and still is) using wired network , which we call it as Landline Telephone.
But the rapid growth of Mobile Communication started to replace the complex wired telephone system. In this scenario, the wired technology became outdated and got replaced by wireless communication.
Another scenario where wireless communication got replaced by wired communication is Television broadcasting. In the early days, television signals were broadcasted using wireless radio transmitters. But this setup got replaced by cable television.
These two examples point out that with the development of technology, we always have to choose what's best for the situation i.e., in some areas we have to use wired communication whereas in the other, going for wireless may be a better option.
Wallys' products It is also constantly upgraded, from WIFI5 to WIFI6, the chipset is also from IPQ4019 to IPQ8072 and so on, Wallys is always the most cutting-edge wireless technology of the times!
1. DR40X9
https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html
https://www.youtube.com/watch?v=6A9pKXP_lBM
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
! d  ]8 B4 Y: v. ^) i/ \0 T
2. DR8072V01
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html
https://www.youtube.com/watch?v=-WxNI6WXFDI&t=22s
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory
1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range
2.412~2.472GHz,
5.150~5.825GHz
M.2 Slot
1x M.2 Slot with PCIe 3.0
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20oC to 70oC,
Storage: -40oC to 90oC
Flash
NOR Flash: 8 MB
NAND Flash: 256MB(1GB optional)
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons
1x S/W Reset Button
DC Jack Input
1x DC Jack Connector: 12V
Interface
4x 1Gbps Ethernet Port,
1x 10Gbps Ethernet Port
1x 10Gbps SFP
2x USB 3.0 Port
1x JTAG 20 Pin Connector
1x Serial Port 4 Pin Connector
LED
2x RGB LED Indicators
Power Consumption
TBD
The following are our main chips and website information, if you are interested in our products, you can also directly contact our mailbox, we will provide you with the best service!
FYI, Wallys are able to provide customizable solutions based on your your Spec requirements for applications, feel free to let me know if any question
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW/ AP9342
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win -win cooperation.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales3@wallystech.com
Best regards
1 i: Z" N3 V0 h6 f; ]0 N+ q
