查看: 2105|回复: 3
刚安装的matlab2019a为什么一打开就有这个错误啊
发表于 2022-9-16 17:25:34 | 显示全部楼层 |阅读模式
每写个字母就重复出现一次,有没有大佬帮忙看一下
Exception in thread "Startup Class Loader": java.lang.NoClassDefFoundError: Could not initialize class com.mathworks.instutil.InstutilResourceKeys
at com.mathworks.mlwidgets.help.DocCenterRoot.initDocRelease(DocCenterRoot.java:44)
at com.mathworks.mlwidgets.help.DocCenterRoot.<clinit>(DocCenterRoot.java:26)
at com.mathworks.mlwidgets.help.HelpPrefs.<clinit>(HelpPrefs.java:49)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at com.mathworks.mlservices.MLHelpServices.getDocRoot(MLHelpServices.java:522)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.getDocrootDirectory(ProductInfoUtils.java:698)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.getAbsolutePath(ProductInfoUtils.java:685)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.parseFile(ProductInfoUtils.java:250)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.parseFiles(ProductInfoUtils.java:310)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.pathChanged(ProductInfoUtils.java:154)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.<init>(ProductInfoUtils.java:80)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.getAllProductsInfo(ProductInfoUtils.java:887)
at com.mathworks.mlwidgets.util.productinfo.ProductInfoUtils.<clinit>(ProductInfoUtils.java:66)
at com.mathworks.mde.desk.StartupClassLoader$LoadInfo.<init>(StartupClassLoader.java:112)
at com.mathworks.mde.desk.StartupClassLoader.createLoadInfos(StartupClassLoader.java:202)
at com.mathworks.mde.desk.StartupClassLoader.access$500(StartupClassLoader.java:25)
at com.mathworks.mde.desk.StartupClassLoader$2.run(StartupClassLoader.java:223)
at java.lang.Thread.run(Thread.java:748)
Exception in thread "AWT-EventQueue-0": java.lang.NoClassDefFoundError: Could not initialize class com.mathworks.instutil.InstutilResourceKeys
at com.mathworks.matlab_login.MatlabLogin.getInfoToCallEmbeddedLogin(Unknown Source)
at com.mathworks.mde.desk.LoginStatusIndicator.setupLoginButtonAndUI(LoginStatusIndicator.java:223)
at com.mathworks.mde.desk.LoginStatusIndicator.access$100(LoginStatusIndicator.java:52)
at com.mathworks.mde.desk.LoginStatusIndicator$2$1.run(LoginStatusIndicator.java:166)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
发表于 2022-9-16 17:25:48 | 显示全部楼层
楼主解决了吗
发表于 2022-9-16 17:26:41 | 显示全部楼层
这个该怎么办啊
发表于 2022-9-16 17:26:53 | 显示全部楼层
楼主我也是这个问题,你是咋解决的?
