查看: 1624|回复: 0
Wallys industrial wifi6 2.4G router/IPQ5018, 802.11ax,wifi 6e,QCN9074
发表于 2022-9-22 17:48:28 | 显示全部楼层 |阅读模式
Wallys industrial wifi6 2.4G router/IPQ5018, 802.11ax,wifi 6e,QCN9074,supportBT5.1APPLICATIONS
Profi WiFi hotspot coverage
Commercial radio coverage
Hotel Wireless application
Country coverage
Internet for passengers (bus, train, plane, …)
Security Surveillance
Some special scene application
Heavy-duty industrial environment use
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;
M.2 Card Slot for QCN9074 WIFI 6E Card
  • Absolute Maximum Rating
  • Parameter****
    Rating****Unit****
    Supply Voltage
    12V
    Operating Temperature Range
    -40 to +70oC
    Storage Temperature Range
    -45 to +105oC
    Operating Humidity Range
    5 to +95 (non-condensing)%
  • ****Hardware Specifications
  • Symbol****Parameter****
    CPUQualcomm-Atheros IPQ5018
    CPU FrequencyDual-core ARM 64 bit A53 @1.0 GHz processor
    System Memory512MB DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port4 x 1Gbps Ethernet Ports  or 1 x 1Gbps Ethernet Port & Poe
    NGFF SlotM.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
    EMMC4G/8G(optional)
    USB /header1x USB 3.0 Port
    POENA
    DC Jack12V power supply
    LED headerLED for power ,Wifi strength
    Serial Portsupport
    WirelessOn-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain2x IPEX Connectors
    BluetoothBT5.1
    Nor Flash8MB
    Nand Flash128 MB
    DDR512MB
    Dimension 170mm x 120mm x 15mm
  • ****Radio TX Specifications(2412MHz-2482MHz)
  • Operating ModeData RatePowerTolerance
    1 Chain****2 Chains****
    2.4Ghz 802.11ax HE20MCS023dbm26dbm±2dB
    MCS123dBm26dBm±2dB
    MCS223dBm26dBm±2dB
    MCS323dBm26dBm±2dB
    MCS423dBm26dBm±2dB
    MCS523dBm26dBm±2dB
    MCS623dBm26dBm±2dB
    MCS722dBm25dBm±2dB
    MCS821dBm24dBm±2dB
    MCS921dBm24dBm±2dB
    MCS1018dBm21dBm±2dB
    MCS1117dbm20dbm±2dB
    2.4Ghz 802.11ax HE40MCS023dbm26dbm±2dB
    MCS123dBm26dBm±2dB
    MCS223dBm26dBm±2dB
    MCS323dBm26dBm±2dB
    MCS423dBm26dBm±2dB
    MCS523dBm26dBm±2dB
    MCS623dBm26dBm±2dB
    MCS722dBm25dBm±2dB
    MCS821dBm24dBm±2dB
    MCS921dBm24dBm±2dB
    MCS1021dBm24dBm±2dB
    MCS1119dbm22dbm±2dB
  • We'll start with a quick review of how Wi-Fi has changed over the years.
In fact, the earliest generation of 802.11 standard can be traced back to 1997, when the wireless speed is very low, only 2Mbps, it is an original standard of the first generation .
With the introduction of 802.11b in 1999, the physical layer speed was increased to 11Mbps and there were very few commercial applications. At that time, Wi-Fi was still far away from people's lives
In 2003, the third generation of the standard, 802.11a/ g. Laptop began to configure wireless network card and home wireless router appeared in large quantity . Wi-fi comes into ordinary family.
EMAIL:sales@wallystech.com
WEB:  https://www.wallystech.com/
Youtube:  https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
作者:wifi6
链接:https://juejin.cn/post/7146135919253258247/
来源:稀土掘金
著作权归作者所有。商业转载请联系作者获得授权,非商业转载请注明出处。
