查看: 889|回复: 0
Wallys industrial 2x2 2.4G&5G router/QCN9074 IPQ6010,802.11ax
发表于 2022-9-23 13:51:27 | 显示全部楼层 |阅读模式
Wallys industrial 2x2 2.4G&5G router/QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax
We developed and designed the industrial router/industrial moudle/industrial antenna.
The chips are mainly Qualcomm and MTK.
At the same time provide customized services.
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
[td]
Absolute Maximum Rating
[td]
Parameter
RatingUnit
Supply Voltage
24V~48V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
[td]
Hardware Specifications
[td]
SymbolParameter
CPUQualcomm-AtherosIPQ6010
CPU FrequencyQuad-core ARM 64 bit A53 @1.8 GHz processor
System Memory1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port1x 1Gbps Ethernet Ports & POE3x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF SlotM.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot1x SD Card Slot
USB /header1x USB 2.0 Port
POE24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack24V power supply
LED headerFFC/FPC Connector
Serial Port1x Serial Port 4 Pin Connector
WirelessOn-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain4 x MMCX Connectors
Bluetoothoptional
Nor Flash8-32MB(normally is 8MB)
Nand Flash256MB
DDR1GB
Dimension185mm x 116mm
[td]
Radio TX Specifications(5180MHz-5825MHz)
[td]
Operating ModeData RatePowerTolerance
1 Chain2 Chains
5Ghz 802.11ax HE20MCS020dBm23dbm
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE400MCS020dBm23dbm
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE80MCS020dBm23dbm
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
Wallys could help clients build Prototype. We have a professional technical team supporting.
    Helping you realize your idea is our aspiration. Everything on RF is our enthusiasm. Different chipsets, different materials, different features, different designs...we could realize all you want.
    Making your idea visible and alive is what we persuit.
Skype/ EMAIL:sales@wallystech.com
WEB: https://www.wallystech.com/
Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
