查看: 1760|回复: 0
Wallys|IPQ6010,802.11ax 2x2 2.4G&5G QCN9074 WiFi 6E Card OpenWRT
发表于 2022-10-12 09:56:15 | 显示全部楼层 |阅读模式
With a history of 10 years, Wallys has been very mature in the design and development of hardware and software in wireless communication. It also supports customization and software development, and has won the trust of 90% of customers around the world and reached a long-term cooperative relationship. It is also a supplier of facebook.
Wallys mainly uses Qualcomm and MTK chips. The main products include router, moudle, industrial access AP and antenna, which are of industrial grade, and the quality and performance fully meet the requirements of users.
The following are the best-selling products of Wallys. Let's take a look at them together. You can contact us at any time if you are in need, or enter our company's official website to check more product information.
Skype/EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
DR6018
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
    SD Card Slot
    1x SD Card Slot
    USB /header
    1x USB 2.0 Port
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V power supply
    LED header
    FFC/FPC Connector
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Bluetoothoptional
    Nor Flash
    8-32MB(normally is 8MB)
    Nand Flash
    256MB
    DDR
    1GB
    Dimension
    185mm x 116mm
DR6018 support QCN9074 series moudle, all move away moudle, go to an example, support DR9074-6E moudle.
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
    Symbol
    Parameter
    Chipset
    WLAN Host Interface
    System Memory
    2Mbit serial I2C bus EEPROM
    Standard Operating Voltage
    5V
    Operating Systems
    QSDK
    Host Interface
    M.2 E Key
    Antenna Cable / Port
    4 x MMCX Connectors,4T4R
    Frequency Range
    5.925GHz-7.125GHz
    Data Rates for WALN
    Channel Spectrum Widths for WLAN
    Support 20/40/80/160MHz at 6GHz
    Modulation Techniques
    OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
    Temperature Range
    Operating: -20°C to 70°C, Storage: -40°C to 90°C
    Humidity
    Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
    Certification
    TBD
    Power Consumption
    TBD
    Reference Design
    PN02.7
    Dimensions (WxHxD)
    57mm x 63mm x 6mm
